How Does an Extra Factor of i Affect Quantum Probability Calculations?
The discussion focuses on the impact of an extra factor of i on quantum probability calculations, particularly in the context of eigenstates and eigenvalues. The calculations for probabilities a_1 and a_2 yield consistent results, both equating to 1/2, but the introduction of the factor i alters the relative phases, which can significantly change the resulting state. The importance of these relative phases is emphasized, as they can lead to different physical interpretations of the quantum states involved. Additionally, there is a query regarding the application of the Hamiltonian when eigenstates are not explicitly provided, with clarifications on how to approach the problem using the given basis. Understanding these nuances is crucial for accurate quantum mechanical analysis.
davon806
I am not sure about (c) and (d). Firstly, I calculated the eigenvector of A :
|v_1> = ( |2 > - |1> )/ √(2) ,eigenvalue -2
|v_2> = ( |2> + |1>) / √(2) , eigenvalue 2
For (c), basically it follows from part (b) where the probability of a_1 is given by the formula | <v_1 | ψ > |^2 , and similarly for a_2 ( using v_2)
However, I don't see any reason that an extra factor of i will change the value of those probabilities ? ( I've calculated a_1 and a_2 which are both 1/2, in (b) )
For(d), I would like to use the formula ψ(t) = e^(-iEt/h) ψ(0). However, the eigenstates of the Hamiltonian was not provided. Given the fact that we only have |1> , |2> , |v_1> and |v_2> : How can I use this formula?
In the general case, the Hamiltonian of the system can be written as a 2 × 2 matrix, where the elements of the matrix are given by: H_ij = < i | H | j > . So for example, <2 | A | 1 > = A_21 = 2. Actually A is not the Hamiltonian so I am not even sure whether it is applicable to part (a). Nevertheless I use this in (a). If I was wrong please correct me !
Incorporated in question
OK
For (c), basically it follows from part (b) where the probability of a_1 is given by the formula | <v_1 | ψ > |^2 , and similarly for a_2 ( using v_2) However, I don't see any reason that an extra factor of i will change the value of those probabilities ? ( I've calculated a_1 and a_2 which are both 1/2, in (b) )
The factor of ##i## does make a difference. Did you try calculating the probabilities for this case?
Actually, the eigenstates of H are essentially given. Note that the form of the matrix given for H is for the original basis {|1>, |2>}. What do you get for H|1>?
You are OK here.
Likes davon806
TSny said:
OK
You are OK here.
Hi TSny ,
For (b), firstly I rewrite | ψ > = (1/2√2) ( |v_2> - |v_1> + i√3 |v_1> + i√3 |v_2>)
then I calculated P_a1 = | < v_1 | Ψ > | ^2 = (1/8) | -1 + √3 i |^2 = (1/8) *4 = 1/2 .
Hence we can calculate Φ in a similar way : | Φ > = (1/2√2) ( |v_2> - |v_1> + √3 |v_1> + √3 |v_2>) , so
new P_a1 = | < v_1 | Φ > | ^2 = (1/8) (-1 + √3 )^2 = (1/8) *(2+2√3 ) = (1+√3 )/ 4 > old P_a1?
What is the physical reason behind this? (As asked in (c))
For(d), write |1> = (x y) . H |1> = (E1 0 E2 0) ( x y) = (E1x E2y) ≠ λ|1> ?
OK
OK, except you didn't quite calculate (-1 + √3 )^2 correctly.
I don't think I can give you a decent physical reason. But it's important to understand that when you expand a state in terms of basis vectors, the relative phases of the coefficients of the expansion are very important. Changing the relative phase changes the state. So, the state (1/√2)( |1> + |2> ) is a different state than (1/√2)( |1> + i |2> ), even though the magnitudes of the coefficients are the same in each state.
For example, if |1> represents the spin state of a spin 1/2 particle where the spin is definitely "up along the z-direction" and if |2> represents the state of the particle where the spin is definitely "down along the z-direction", then (1/√2)( |1> + |2> ) is the state where the spin is definitely along the +x direction while (1/√2)( |1> + i |2> ) is the state where the spin is definitely along the +y direction. So, the presence of the i makes a big difference.
For(d),
You are working with matrices that are written with respect to the basis vectors |1> and |2>. So, the column vector that represents |1> would be (1 0)T.
Likes davon806
del
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
