How Does Contour Integration of Complex Functions Help Compute Integrals?
  • Thread starter Thread starter Math Monster
    Integration
The discussion focuses on evaluating the integral ∫_0^∞ (s^a-1)/(s-1) ds using contour integration techniques. Participants suggest using the function f(z) = z^(a-1)/(z-1) and integrating along a contour that includes a large circle and branch cuts to handle singularities at s=0 and s=1. There is a consensus that the integral can be approached by breaking it into segments and applying the Residue Theorem. The importance of correctly handling the branch points and the contributions from different segments of the contour is emphasized. Overall, the conversation aims to clarify the steps needed to compute the integral accurately.
Math Monster
Show that the formula:
∫_0^∞ (s^a-1)/(s-1) ds = -pi cot (a pi)
may be calculated by considering an analytical branch of function:
f(z) = z^(a-1) / (z-1)
and integrating along a contour consisting of:
a) a circle radius R, centred at (0,0)
b) with a branch cut running from (0,0) to R above and below the x-axis
c) circular contours around singularity (0,0) and (1,0)
when R→∞
I have attempted to substitute s=Re^i alpha z, and I believe the integral around (a) → 0 as R → infinity but i can't really make sense of it all!
Please help and thanks in advance!
when R→∞
Is it:
\text{P.V}\int_0^{\infty}\frac{s^{a-1}}{s-1}ds,\quad 0<a<1
If so, then just work a simple one first: Let a=1/2 and consider
\text{P.V}\int_0^{\infty} \frac{1}{\sqrt{s}(s-1)}ds
That's 8 integrals right? Can you set up some of them?
NB I tried to write this as Latex but not sure how to transfer it! If you can give me a hint I will try to repost so that it is easier to read!
I think so...
This has singularies at s=0 and s=1, same as my example.
Start with $s = e^{iz}$ and so $ds = ize^{iz} dz$
I've left it in terms of s for ease of typing, but realize that this transformation should be made (if I'm right that is!).
If i break my contour up into
$C_{R2} : \\*
\int^{-R}_{R} \frac{1}{\sqrt{s}(s-1)} ds $
$C_{1}: \\*
\int^{1+ε}_{R} \frac{1}{\sqrt{s}(s-1)} ds \\*
NB: y has no relevance, i.e. z=x, and so we integrate over x $
$C_{r_1}: \\*
\int_{1+ε}^{1-e} \frac{1}{\sqrt{s}(s-1)} ds \\*
Thinking maybe this should be integrated 0:pi?
$C_{3}: \\*
\int_{1-ε}^{0+ε} \frac{1}{\sqrt{s}(s-1)} ds \\*
$C_{r_2}: \\*
\int_{0}^{2 pi} \frac{1}{\sqrt{s}(s-1)} ds \\*
Not sure about this one? I think maybe we do over dz? And the circle should have radius ε?
$C_{4}: \\*
\int^{1-ε}_{0+ε} \frac{1}{\sqrt{s}(s-1)} ds \\*
$C_{r_{-1}}: \\*
\int^{1+ε}_{1-e} \frac{1}{\sqrt{s}(s-1)} ds \\*
Following from C_{4} I'm thinking maybe this should also be integrated 0:pi?
$C_{1}: \\*
\int_{1+ε}^{R} \frac{1}{\sqrt{s}(s-1)} ds \\*
Then the integral of the contour is the sum of these 8.
Am I anywhere near the right lines?
Also, just wanted to confirm that yes, 0<a<1.
Many thanks
Use and, or if you want it to be in the centre of the screen, on its own line. Using , I suggest you use \displaystyle.
You need to enclose math code in \text{}and \text{}. Tell you what, If I start with the leg from 0 to 1 above the real axis, go to infinity, around the circle z=Re^{it}, and then over the leg below the real axis back to the origin, then around it via z=\rho e^{it}, I get by the Residue Theorem:
\text{P.V.}\int_0^1 f(z)dz-\pi i r_a+\text{P.V} \int_1^{\infty} f(z)dz+\mathop\int\limits_R f(z)dz+\text{P.V} \int_{\infty}^1 (-f(z))dz-\pi i r_b+\text{P.V}\int_1^0 (-f(z))dz+\mathop\int\limits_{\rho} f(z)dz=0
Note the contours over the indentaitons around the pole at 1 is just -pi i times it's residue. Just for now, say the contour over the big and little circle is zero. Justify that for the purist later. Also, when we go around the branch point and onto the leg below the real axis, the value of the root changes by e^{2\pi i/2}. That gives the negatives along those contours. If it was \sqrt[3]{z}, and we go around once, it would change by e^{2\pi i/3} and so forth. Keep that in mind when you consider a=2/3. Combine all those principal values into one cus' it's the same thing and then write:
2\;\text{P.V.}\int_0^{\infty} f(z)dz-\pi i(r_a+r_b)=0
So
\text{Res} (\frac{1}{\sqrt{z}(z-1)},1)=\pm 1
corresponding to the two roots of 1 right? Get that one straight, then adapt it to a=2/3. That one is not zero.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
