A How does DFT handle degenerate eigenvectors?
Mart1234
TL;DR Summary
DFT and degeneracy
I have a question about how DFT (density functional theory) handles degenerate states. The Hamiltonian in DFT is a functional of the electron density defined via ##n(\mathbf{r})=\sum^N_{k=1}|\psi_k(\mathbf{r})|^2##. However, say I have a pair of degenerate states. Then any linear combination of these two states is also a solution to the Kohn-Sham equations and the electron density based on the above definition seems to be not well defined. How does DFT address this? Is there a constraint for degenerate states which picks a proper orientation?
Hm, each of the degenerate states has it's own density. E.g. if degeneracy is due to rotational degeneracy, as an example, psi might be a p orbital. As they are degenerate, the orbital can point in any direction and the corresponding electronic density will be concentrated along the same direction.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
