How Does Electron Charge Density Affect Electric Field in a Hydrogen Atom?
The discussion focuses on the relationship between electron charge density and the electric field in a hydrogen atom's ground state. The charge density is expressed as p(r) = -e/πa^3 exp(-2r/a), where a is the Bohr radius. The electric field E(r) is derived from this charge density, leading to a specific formula that incorporates exponential decay and radial dependence. The solution involves integrating the electric field over all space, which is justified by the spherical symmetry of the charge distribution. Applying Gauss' Law simplifies the understanding of how the electric field behaves at different distances from the nucleus.
bon
The electron charge density of a hydrogen atom in its ground state is given by:
p(r) = -e/ pi a^3 exp(-2r/a) where a is the Bohr radius
Show the E field due to the cloud is given by:
E(r) = e/4pi episllon0 ( (exp(-2r/a) -1)/r^2 + 2exp(-2r/a)/ar + 2exp(-2r/a)/a^2)
I know that the E field is given by: http://en.wikipedia.org/wiki/Coulomb\'s_law#Continuous_charge_distribution
I\'m trying to understand a solution I\'ve been provided with... but the solution takes out a factor of 1/4pi e0 r^2 then integrates the expression over all space (r\' ^2 sintheta, dtheta dphi dr\') to get the right answer..
I don't understand why this works...surely each little element of charge is a different distance away from the point r (i.e. r-r\')?
Can anyone explain this to me?
Thanks!
In the ground state, the charge distribution has spherical symmetry, independent on direction. It can be assumed the same for the electric field that it is function of r alone. Apply Gauss' Law.
ehild
