How Does Energy Increase in an RL Circuit with Time-Varying Current?
The discussion revolves around calculating the increase in energy stored in an inductor as the current changes from 3 A to 5 A over 1 second. The voltage across the inductor during this time is 4 μV. Participants suggest using the formula U=1/2 I^2L to find the energy, emphasizing the need to first determine the inductance (L) using a derivative-based formula. The conversation highlights the relationship between voltage, current change rate, and inductance in understanding energy dynamics in an RL circuit. The final energy increase calculated is 16 μJ.
syhpui2
An inductor initially has 3 A of current passing through it at time t = 0. The current through the inductor increases at a constant rate until 5 A of current is flowing through it 1s later at t = 1 s. The voltage across the inductor is 4 μV while the current is increasing. What is the increase in the energy stored in the inductor between t = 0 and t = 1 s?
Answer: 16 μJ
KVL, KCL
I can use U=1/2 I^2L to find the energy? But how energy increased? And how can I find current over inductor?
Thx
Thx
I suggest that you find the inductance L first. What's the defining formula for inductance (hint: it involves a derivative).
Once you have the inductance you can determine the energy stored for each level of current.
So I just use V/ (dl/dt)?
Try it and find out!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
