Exuro89
- 34
- 1
Two blocks with masses 4.00 kg and 8.00 kg are connected by a string and side down a 30.0 inclined plane. The coefficient of kinetic friction between the 4.00kg block and the plane is .25; tha between the 8.00kg block and the plane is .35.
(a) Calculate the acceleration of each block.
(b) Calculate the tension in the string.
(c) What happens if the positions of the blocks are reversed, so the 4.00kg block is above the 8.00 kg block?
[PLAIN]http://k.min.us/ilSZqW.png
F=ma
Okay so the first thing I do is do fbd of both masses. I then find the x and y component forces of each.
4kg block
Fy= Fn-mgcos(theta)=0
Fn=mgcos(theta)
Fx=T+Fk=ma
T+[tex]\mu[/tex]kmgcos(theta)-mgsin(theta)=-ma
T+[tex]\mu[/tex]kgcos(theta)-g(sin(theta)=-a
8kg block
Fn=mgcos(theta)
Fx=Fk-mgsin(theta)-T=-ma
[tex]\mu[/tex]kmgcos(theta)-mgsin(theta)-T=-ma
[tex]\mu[/tex]kgcos(theta)-gsin(theta)-T=-a
Is this portion correct? I'm not sure how I can find each's acceleration with tension playing a part. If my math is right, without tension the first block would be going at 2.778m/s^2 and the larger block is going 1.9295m/s^2.
So with tension that would mean the first block is -a = T/4-2.778 and the second block -a = -T/8-1.9295. Is that all it's asking for for acceleration?
Would I then equal those equations to get T = 2.26N?
And for part C if the bocks were switched, T would be 0 and the 4kg block would run into the larger block. Is this correct?
