I How Does Gravity Affect Spectral Line Strength?
The relationship between spectral line strength and gravity is complex, as it involves multiple factors such as oscillator strength, elemental abundance, temperature, and pressure. The equivalent width of spectral lines, like Ca II, can decrease with increasing gravity, but this is not a straightforward correlation. Changes in gravity affect atmospheric pressure, which in turn influences the structure and spectral class of a star. Additionally, electron and gas pressure contribute to line shape through pressure broadening, but the line width is not directly proportional to pressure due to the complexities of radiative transfer. Understanding these interactions requires solving intricate radiation transport problems within model atmospheres.
Angela G
TL;DR Summary
Hello,
I wonder if someone please could explain what the relationship between a spectral line strength and gravity is? Does the equivalent width of e.g. Ca II decrease with increasing gravity? what kind of processes affects the strength of a line if we change the gravity of a star?
Hope you can help me
Astronomy news on Phys.org
There is no simple relationship. The equivalent width of a spectral line depends on the oscillator strength (an atomic parameter), the elemental abundance, temperature (ionization states) and pressure, and can only be obtained by solving a complicated radiation transport problem in a model atmosphere. The pressure depends, of course, on the star's gravity and determines the structure of its atmosphere and the spectral class. Electron and gas pressure have an influence on the line shape (causing "pressure broadening"), but the resulting line width is not simply proportional to the pressure because of the intricacies of radiative transfer. Spectral lines are formed in layers with temperature and pressure gradients.
Hope this helps. :-)
Likes Angela G, berkeman and FactChecker
Thank you very much!
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
