How Does Inserting a Dielectric Material Affect Capacitor Charge?
Inserting a dielectric material into a parallel-plate capacitor increases its capacitance, allowing more charge to flow from the battery while maintaining the same voltage. The initial capacitance for the vacuum-insulated capacitor was calculated to be 7.29e-9 F, while the capacitance with the dielectric became 3.5e-8 F. The charge on the plates with the dielectric was found to be 1.75e-6 C, compared to the vacuum-insulated charge of 3.64e-7 C. The additional charge flowing from the battery was initially miscalculated due to errors in determining the capacitance. Correcting these calculations is essential for finding the accurate additional charge.
kopinator
A parallel-plate air capacitor of area A= 21.0 cm2 and plate separation d= 3.20 mm is charged by a battery to a voltage 50.0 V. If a dielectric material with κ = 4.80 is inserted so that it fills the volume between the plates (with the capacitor still connected to the battery), how much additional charge will flow from the battery onto the positive plate?
C= ε0A/d
Q=C(dV)
C= κC_0_
Q= κQ_0_
Using the first equation, I found the capacitance for the vacuum-insulated capacitor. Then I found the change in capacitance using C=κC_0_. I got C_0_(vacuum-insulated capacitance) to be 7.29e-9 F and got C(dielectric-insulated capacitance) to 3.5e-8. I know that while the capacitor is hooked up to the battery, the potential difference(dV) does not change. So I used Q= C(dV) to find the charge on the plates with dielectric in between which was 1.75e-6 C. I also found the Q_0_(vacuum-insulated charge) to be 3.64e-7 C. I took the difference of the two and got 1.38e-6 C. I thought this was the answer but it was wrong. The problem asks, "how much additional charge will flow from the battery onto the positive plate?" though. I feel I'm missing something but I don't know what.
Likes gracy
Looks like you understand the problem very clearly.
But there may be something wrong with the capacitance calcs:
I get C = ε₀A/d = 8.854E-12*21E-4 / 3.2E-3 = 5.81 E-12
which is more than a thousand times smaller than your value.
Mind you, I'm struggling a bit with calculations these days.
I think i figured out my problem. My was miscalculating my ε_0_ but I got it now. Thank you!
Most welcome!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
