B How Does Liquid Density and Viscosity Influence Free Fall Braking?
Liquid density and viscosity significantly influence the behavior of objects in free fall through fluids. The buoyancy experienced by an object is determined by its density relative to the liquid, affecting how quickly it descends. In a liquid like glucose, which has a lower density than gold and stone, the denser objects will experience greater buoyant forces, potentially slowing their fall. Viscosity also plays a crucial role, as it contributes to the drag force acting on the falling objects, impacting their terminal velocity. Understanding these factors is essential for predicting the motion of different density objects in liquids.
Arbegator
TL;DR Summary
If two objects with big diffrence in density but the same size travel through a liquid closer to the density of one of the objects, does it slow down the free fall?
In mine hypothesis I want to slow down free fall for diffrent density objects in liqudies. I have a stone wich i roughly a denisty of 2,7 g/ml and gold with 19,7 g/ml. They have the same size. Liquied glucose has the density of roughly 1,5 g/ml. In my example, I drop at the same time in a 1 meter pipe with glucose. How does the density affect the buoyancy with free fall? Does Viscosity matter in this case? Will gold fall faster?
Thank you for your help with trying to sort this out.
Welcome to PF. :smile:
It certainly seems like it will have some effect. Can you post links to the reading you have been doing so far on this question?
Also, is this question for schoolwork? Thanks.
Density is important because the driving force is due to the weight, less the buoyancy of the object in the fluid.
Viscosity is critical in that it is part of the drag equation. Terminal velocity is reached when the falling body drag balances the driving force.
https://en.wikipedia.org/wiki/Drag_(physics)#Very_low_Reynolds_numbers:_Stokes'_drag
Likes russ_watters
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
