How Does Magnetic Force Affect a Wire in a Field?
The discussion focuses on calculating the magnetic force acting on a wire carrying a current in a magnetic field. The wire, oriented along the x-axis, has a current of 2.3 A flowing in the positive x direction, while the magnetic field is 0.82 tesla in the positive y direction. The relevant equation for determining the force is F = I * L x B, where L is the length of the wire in the magnetic field. Participants highlight the challenge of determining the appropriate length L to use in the calculation. Understanding the interaction between the current and the magnetic field is crucial for solving the problem effectively.
sdevoe
A wire is oriented along the x-axis. It is connected to two batteries, and a conventional current of 2.3 A runs through the wire, in the +x direction. Along 0.27 m of the length of the wire there is a magnetic field of 0.82 tesla in the +y direction, due to a large magnet nearby. At other locations in the circuit, the magnetic field due to external sources is negligible.
What is direction and magnitude of the magnetic force on the wire?
no clue
nothing?
There is an equation that relates the force on a wire of length L to the current I flowing and the magnetic field strength B. See if you can find it.
F=I*LxB?
Yes, that's the one.
The tricky part is what to use for L.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
