How does NH3 have 2 rotation axes?
In summary: NH3 has C3v symmetry. It has no C2 axis.Yes the trigonal pyramidal... NH3 has C3v symmetry. It has no C2 axis.
ampakine
60
According to the character table for the C3v point group there are 2 C3 rotation axes along the z axis. How are there 2 of them? There is only 1 listed in the C2v point group table which makes sense but I can't see how a molecule like NH3 has more than one rotation axis along the z axis.
Chemistry news on Phys.org
You can rotate around the axis in either direction.
There is only one axis, but two (or in reality 3) rotations (=symmetry elements): rotations by 0, 120 and 240 degrees.
That is correct, but it is also the same as my answer. A rotation by 120 degrees is equivalent to a rotation by -120 degrees. Of course rotation by 0 degrees is equivalent to the identity element, E.
who said that ammonia has 2 rotations axes? it has only one rotation axis which is C2 axis,
check here :
http://www.chemeddl.org/labs/avisualdatabase/index.php
and look for ammonia, and see symmetry properties.
What about BrF5 then. It belongs to the C4v point group and according to here:
http://www.webqc.org/symmetrypointgroup-c4v.html
it has 2 C4 rotations and a C2 rotation. SpectralCats explanation works better here because if a 270 degree rotation can be considered a C4 rotation then why couldn't a 180 degree rotation?
check here :
How can a 180 degree rotation of a trigonal pyramidal molecule be a symmetry element?
look if you have a type of AB3 molecules with similar 3 atoms like NH3 then you have one rotation improper axis which is C2 this axis is passing through each H atom hence you have only one C2 axis since the 3 atoms are the same, but how does this axis process 180 symmetry?..this needs a bit visualization from you..
if you have a planar NH3 (that is a molecule drawn on planar paper with no 3D dimensions) and keeps in your mind the image of the C2 passing through one of the H atom, if you turn the paper to 180 degree (turn the paper to other side) you will have the left H atom in the right position and versa. and this is also with other atoms.
Notice also that NH3 has also C3 axis but this once passes through Nitrogen atom perpendicular to it (axis goes from the paper to out), that is if you rotate the molecules around the inner axis by 120 degree(that is the angel between 2 H atoms) you will actually have the same H positions which is another symmetry.
got it?
got it?
Except that NH3 is not planar .. you are describing D3h symmetry .. NH3 has C3v symmetry, and the OP is correct that it has no C2 axes.
Yes the trigonal pyramidal structure has only the C3 axis but there is no C2 axis, i mentioned the trigonal planar structure in my previous discussion.
http://www.chemeddl.org/labs/avisualdatabase/index.php?molecule=1&sort=name&kind=all&molecule2=-1&sort2=name
My point is that you are confusing the OP, because he asked about NH3 specifically, which is non-planar with C3v symmetry. Answering a question about another structure with another symmetry is not really relevant to his question.
Also you did NOT mention trigonal planar geometry in your initial response to the OP:
check here :
That response is just as wrong for a trigonal planar structure with D3h symmetry, which has one C3 xis and 3 C2 axes perpendicular to C3 axis.
What was the point of linking that website? It shows NH3 as non-planar with C3v symmetry also ... which is good, because otherwise it would be (very) wrong.
Yes, that is correct. There are 4 permutations around the central 4-fold axis of symmetry corresponding to rotations of 90, 180, 270 (or -90) and 360 (or 0) degrees. The 180 degree rotation is equivalent to a C2 operation, while the rotations of 90 & -90 correspond to the two C4 operations.
Related to How does NH3 have 2 rotation axes?
1. How does NH3 have 2 rotation axes?
NH3, or ammonia, has 2 rotation axes due to its molecular structure. The central nitrogen atom is bonded to three hydrogen atoms in a trigonal pyramidal shape. This allows the molecule to rotate around two different axes - the vertical axis passing through the nitrogen atom and the horizontal axis passing through the nitrogen-hydrogen bonds.
2. What is the significance of NH3 having 2 rotation axes?
The presence of 2 rotation axes in NH3 allows for increased flexibility and movement of the molecule. This is important in various chemical reactions and interactions that NH3 is involved in, such as in biological processes and industrial applications.
3. How do the rotation axes in NH3 affect its properties?
The two rotation axes in NH3 allow for different conformations of the molecule, resulting in variations in its physical and chemical properties. For example, the energy required for rotation around the axes can affect the molecule's stability and reactivity.
4. Can NH3 rotate freely around both of its axes?
No, NH3 cannot rotate freely around both of its axes. The rotation around the vertical axis is relatively free, but the rotation around the horizontal axis is more restricted due to the hydrogen atoms being closer together and the presence of lone pair electrons on the nitrogen atom.
5. How do the rotation axes in NH3 affect its symmetry?
The presence of 2 rotation axes in NH3 results in a C3v point group symmetry. This means that the molecule has three identical C3 rotation operations and three perpendicular C2 rotation operations, which contribute to its overall symmetry and properties.
