How Does Power Consumption Compare Between AC and DC in a Single Device?
The discussion focuses on the comparison of power consumption between AC and DC for a single device. When a device drawing 500W at 120VAC is connected to a 12VDC system via an inverter, the current draw on the DC side can be calculated as 41.6 amps, assuming no losses. However, inverter efficiency must be considered, which typically ranges from 70% to over 90%, affecting the actual current draw. If the inverter is less efficient, the current draw increases accordingly. The conversation emphasizes the importance of accounting for real-world inefficiencies when calculating power consumption.
pmpstyles
Hello, I just came across this site when looking for some info. Not sure if this is a stupid question but I would like to know what the correlation between AC and DC power is when comparing one device. For example if i had a a device connected to 120vac and it drew 500w then the amps would be 4.16. So if i use that same device and connect it to a power inverter on a 12vdc system, it would draw that same power through the inverter, but what would be the draw on the 12vdc side? Is it just simply 500w/12v=41.6amps. I am basically trying to figure how much AC power can be drawn from a 12vdc battery where 50a is the max current the can go through a dc meter. Thank you
12 V x 50 A = 600 W. An upper limit (some losses in the DC-AC converter)
But my guess is the battery can't deliver that for very long ...
Likes anorlunda
You are quite correct in your calculation of the power needed, but, as BvU indicates, the inverter is not 100% efficient. So you need to divide your calculated result by the efficiency.
So if the inverter were 70% efficient, the current draw would be 41.6 / 0.70 = 59.4 A.
But I don't know what a typical efficiency would be. (I have found a reference that suggests it can be in excess of 90%, which would mean 41.6/0.90=46.2A)
Also, the inverter might not deliver the 120V AC you expect. If it delivers less, then your device might not draw its full 500W, then the 12V current could be less.
Sorry, I was just going hypothetically. If everything was 100% efficient and a device plugged into a home outlet drew 500w over 120v, then the amps would be 4.16. In theory, if the same device ran 500w over 120v on a 12v battery. What are the numbers for the voltage, amps, and watts coming from the battery and going to the inverter? Is it simply calculating the amps because we know the voltage of the battery (12v), we know that the device used 500w over A/C, then would that give the answer or is it some random number? Hopefully that makes sense.
yes, as stated in your OP
but remember, as you have been told, it's a long way from the real world, so don't try and use
the figures to produce good infoDave
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
