MHB How Does Removing the Amplitude Factor Improve Ball Bounce Modelling?
Removing the amplitude factor from the bounce model improves accuracy by eliminating unnecessary proportional decay in height, as the original amplitude (a=0.5) reduces the bounce height too much. The new function h(x) reflects a more realistic bounce by focusing on the sine component while still incorporating the exponential decay effect. This adjustment allows for a more precise representation of the ball's behavior after each bounce. The discussion highlights the importance of understanding how amplitude affects the overall model and its implications for real-world scenarios. Accurate modeling of ball bounce dynamics is crucial for applications in physics and engineering.
Kaspelek
Hi guys, just an intuitive question I've come across. Quite ambiguous, not sure on the correct response.
So basically I'm given a scenario where I'm provided the data of an actual height vs time points of a vertical ball drop and it's bounce up and back down etc.
Question starts off where I have to model the height and time of the bounce using the points given to the equation f(x)=|a*sin(b(x-c))|
Hence i work out a, b and c a=0.5, b=3, c=0.6 and drew the graph.
Commented on the fit of the model.Next I am asked to create a new function s(x) where it is created by multiplying the original f(x) function by an exponential function e(x) i.e. s(x)=e(x)*f(x).
This provides a decaying effect of the height, hence more realistic.
Finally, I am asked to draw a new function, h(x), whereby i only remove the value a from the f(x) function so h(x)=e(x)*|sin(b(x-c))|.
I am then asked, Having removed a=0.5 in f(x), why does this give a more accurate model than s(x).My thoughts?
I believe it is because that since the value of a is less than 1, the height of the ball bounce is proportionally decreasing unnecessarily when comparing the h(x) and s(x) models respectively.
Thoughts guys?Thanks in advance.
Mathematics news on Phys.org
By the time you get to the first bounce, the decaying amplitude (which should presumably be $e^{-x}$) is:
$$e^{-0.6}\approx0.55$$
and this is closer to 0.5 than half that value.
Suggested that the response is worth 2 marks, thinking there's more.
What has the amplitude decayed to when the ball reaches it's peak after the first bounce? Unless you know some differential calculus, you will have to rely on a graph...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
