How Does Reversing Current Direction Affect Magnet Position in a Coil?
  • Thread starter Thread starter carpekd
    Behavior
Reversing the current direction in a cylindrical coil changes the magnetic polarity, making side A the north pole and side B the south pole. When the current is reversed, the permanent magnet will move towards side B and settle with its north end aligned with the north pole of the coil's B side. This behavior is analogous to two permanent magnets attracting each other at their respective poles. The initial position of the magnet affects its final resting place based on the polarity of the coil. Understanding this interaction is crucial for applications involving electromagnetism and magnetic positioning.
carpekd
Hello all,
In the sketch attached below, I have a cylindrical coil with a cylindrical permanent magnet located in the center (assume the magnet can only move in the axial A-B direction). It is my understanding that if the coil had current flowing through it so that side A was the south pole and side B was the north, and the permanent magnet started in the position shown, the permanent magnet would move towards A and settle in the center of the coil (please correct me if that is inaccurate). What I can't visualize is where the permanent magnet would settle (again starting from the position shown) if the current was reversed and the A side was the North pole and the B side was the south pole... Would the north end of the magnet (the outside surface) line up with the outside surface of the B side on the coil?
Thanks for your help
- confused mech engineer
carpekd said:
Hello all,
Yes. It would be just like two permanent magnets stuck together at a single N-S edge.
Thanks for clearing that up!
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
