How Does Special Relativity Explain the Michelson-Morley Experiment Results?
  • Thread starter Thread starter ultimateroxas
    Einstein
ultimateroxas
How does Einstein’s theory of special Relativity explain the result of the Michelson-Morley experiment?
Thankyou if you can help
the Michelson-Morley experiment set out to measure the presence of the hypothetical luminous aether by measuring the difference in the speed of light of two paths of a split beam of light that are at right angles to each other. assuming the Earth must be traveling through the aether at some time during the year as it revolves around the Sun, this difference of speed should be measurable with their apparatus.
the performed the experiment many times, at different times of day and different seasons of the year and never got a positive result (that is a measurable difference of the speed of light in those two directions).
Einstein simply said "hell, yes. why not? there was no measured difference in the speed of light because there was no difference in the speed of light to measure." that the speed of light (which is really the speed of any instantaneous interaction, E&M, gravity, strong force, whatever) in a vacuum is constant and the same for any (inertial) observer anywhere in any direction is a postulate of SR. from that postulate Einstein notices that all sorts of strange things happen regarding time, length, apparent mass, especially if one observer is whizzing by another at a speed approaching c.
thanks
thankyou so much you helped me alot. thank again
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
