How does temperature affect viscosity of a liquid?
In summary, temperature plays a significant role in the viscosity of fluids. In the case of liquids, an increase in temperature causes molecules to move further apart, resulting in a decrease in viscosity. This is because higher temperatures lead to less bonding between molecules, making the liquid less viscous. In contrast, for gases, an increase in temperature leads to more kinetic interactions between molecules, resulting in an increase in viscosity. However, this is not always true, as there are exceptions such as methyl cellulose solutions which become less viscous when cold. Additionally, pressure and molecular spacing can also have an influence on viscosity, but their effects are not as significant as temperature.
avito009
184
I know that
When there is increase in temperature the molecules in a viscious liquid move further apart and this decreases the viscosity of the fluid.
So does that mean the molecules are far apart in case of liquid and these molecules move further apart with increase in temperature. So a viscious liquid is like a solid because its molecules are closer and lesser viscious liquid has molecules far apart?
Science news on Phys.org
The best application for your question that i can conjure is in hydrocarbons. hydrocarbon viscosity is determined by the length of a carbon molecule, the longer the chain, the more viscous, the shorter the chain, the less viscous. in the case of temperature being a factor, a molecule's kinetic energy will be raised, its atoms will move at a much higher rate, since viscosity is the relationship between one molecule's ability to interact with other molecules by encouraging homogeneous movement, atoms at a higher kinetic level would be more conducive to a less viscous substance as surplus energy is not required to facilitate movement in the corresponding molecules. ultimately what this means is that temperature affects viscosity by increasing the kinetic energy of each atom/molecule. a useful analogy is to imagine you are in a crowded room with a lot of people ( a party). but there is no music. when you move, you might nudge a few people and they move abit (high viscosity). however if the music was on (Music is temperature source) people will start to jump around (kinetic energy), and so do you. when you move, you will find your energy will jolt people more aggressively then if you were stationary, meaning viscosity has decreased.
Most liquids get less viscous with increasing temperature. The trend is reversed in gases.
avito009 said:
<snip>
This is not always true: we use solutions of methyl cellulose, and these are less viscous when cold.
avito009 said:
I know that
Newtonian fluids are simplest to descibe, where viscosity, ie the shear strsss is proportional to the velocity of adjacent layers. Other non-Newtonian fluids have more complex relationships.
You don't relalize it, but you have mentioned 2 variables that could have an influence upon viscosity.
1. temperature
2. pressure
Pressure -
There would be an affect upon molecular spacing, ot rather how far apart the molecules are from one another. This is usually considered to not greatly affect the viscosity of a particular fluid, so molecular spacing cannot be the answer.
Temperature
Molecules move around a lot in liquids and gases, but even so, some interaction will have to occur. This action can be a change in kinetic energy, or velocity of the molecules; or a brief molecular bond between the molecules.
Liquids
Lower temperatures mean lower molecular jostling, meaning more bonds and the bonds can act longer. Higher temperatures results in the converse.
Gases
Gases have less intermolecular bonds forming between them, so the velocity of the molecules must be important.
Viscosity
For a liquid, as a result of temperature, the formation of more or less bonds between molecules in the adjacent layers, affects the viscosity.
Higher temp -> less bonding-> less viscosity
For gases, molecules themselves move between layers. With higher temperatures the molecules will have more interactions, affecting the viscosity.
Higher temp --> more kinetic interactions -> increased viscosity
Related to How does temperature affect viscosity of a liquid?
1. How does temperature affect the viscosity of a liquid?
The viscosity of a liquid is directly affected by temperature. As temperature increases, the viscosity decreases, making the liquid less resistant to flow. This is because higher temperatures cause the molecules in the liquid to move faster, making it easier for them to slide past each other and flow more freely.
2. Why does viscosity decrease with increasing temperature?
The decrease in viscosity with increasing temperature is due to the decrease in intermolecular forces between the molecules of the liquid. As temperature rises, the molecules gain more energy and move more rapidly, causing these forces to weaken and allowing the molecules to move more freely.
3. How does temperature affect the flow rate of a liquid?
The flow rate of a liquid is directly affected by its viscosity, which is in turn affected by temperature. As temperature increases, the viscosity decreases, making the liquid flow more easily and increasing its flow rate.
4. What is the relationship between temperature and viscosity?
Temperature and viscosity have an inverse relationship. This means that as temperature increases, the viscosity decreases, and vice versa. This relationship is due to the changes in molecular movement and intermolecular forces that occur with changes in temperature.
5. How does temperature affect the behavior of a liquid's molecules?
Temperature has a significant impact on the behavior of a liquid's molecules. As temperature increases, the molecules gain more energy and move more rapidly, causing them to spread out and take up more space. This leads to a decrease in viscosity and an increase in the liquid's flow rate.
  • Thermodynamics
  • Thermodynamics
  • Other Physics Topics
