How does the accuracy of the clock change when the spring stretches?
In summary: Yes, that is correct. The question is asking how changes in the amplitude of the pendulum affect the timekeeping accuracy of the clock, specifically in regards to the spring mechanism used to maintain the pendulum's motion.
tomceka
A pendulum clock - is a clock that uses a pendulum, a swinging weight, as its timekeeping element.
Pendulum's amplitude of oscillation decreases with the stretching of the spring. How does the accuracy of the clock change?
1) T=2π√(m/k), T - period of oscillation, k - spring constant
2) T=2π√(l/g),
A longer pendulum swings slower. So changing the length l of the pendulum changes the period T, which affects the timekeeping accuracy. But the problem is talking about the body on the spring, not the string. So the second formula cannot be applied here directly and I don't know how to progress further since the first equation only involves mass and the coefficient which we do not know.
Where is the spring in this picture? Is the bob attached to a pendulum through a spring? I doubt it. Can you post the entire question, specifically the part where "the problem is talking about the body on the spring"?
Likes Delta2 and Lnewqban
On an escapement drive typically the pendulum amplitude is slightly dependent on spring tension hence
"Pendulum's amplitude of oscillation decreases with the stretching of the spring. How does the accuracy of the clock change?"
Yes, it's clearly concerned with the amplitude variation.
@tomceka , you need to go back to the exact form of the pendulum motion equation, the form that still has ##\sin(\theta)## in it. The standard solution, turning it into the SHM equation, results from approximating it as ##\theta##. Suppose we were to keep the next term of the power expansion, ##-\frac 16\theta^3##. Can you figure out roughly how changing the amplitude would affect the period? I think it's not easy.
(Edit: see http://hyperphysics.phy-astr.gsu.edu/hbase/pendl.html)
That said, I am still puzzled by the reference to "stretching" of the spring. Assuming a standard coiled clockwork spring, the spring unwinds and relaxes as it runs down; it never stretches.
I agree with both observations. Seems an odd question with little guidance (for an introductory course).
Is it possible that instead of a fixed rod on the pendulum, it is instead a mass on a spring swinging…that would be more advanced. Or, maybe they introduce the spring as a mechanism to “change the length” of the rod in the problem instead of saying the rod just increases in length, decreasing the amplitude.
Likes Delta2
Ah it is the well known escapement drive aka warp drive o:)
Likes hutchphd
The question states that some change in a spring affects amplitude, and, as I read it, then asks how an amplitude change may affect the period. If so, the correctness of the first part is somewhat academic; we only have to address the second.
Likes erobz
Some pendulum clocks use a spring to store energy. Winding the clock in this case means that a spring is distorted such that it stores energy. Usually a spiral spring, so it is not really "stretching". The spring acts the mechanism that drives the pendulum. The spring has nothing to do with the period, at least not directly. But as the force of the spring may decrease towards the end of the winding cycle it may also change a little the exact positions in which the pendulum is acted/released.
Likes Delta2
It will reduce the amplitude since the torque on the pendulum is weakening. This aspect seems to be the one referred to in the question.
Likes hutchphd
The question seem to be how is the accuracy affected by a change in amplitude. Not how this change in amplitude happens exactly. It would help if they define "accuarcy" for this case.
… as I wrote in post #8.
Good point.. it would be better to ask how it affects the rate.
Likes Delta2
Is this about a pendulum who uses some sort of spring mechanism to recover the energy lost due to friction? So that the pendulum keeps swinging?
Affecting the accuracy isn't necesarilly the same as affecting the period of the pendulum (mentioned in post 8). Maybe it is. This is why I said that we need to know what they mean by this.
If your clock is not broken, yes it is. That's why the clock has a pendulum.
If the escapment mechanism is released every two periods instead of one the accuracy is affected even though the period is not. It does not mean that the clock is broken But I don't think this is possible. Nevermind.
And by some measures a stopped clock is more accurate than one that loses a millisecond a day. But really...
  • Haha
Likes Delta2
Have you heard of classical microcombinative theory?
The reason I agreed with @nasu on this point in post #12 was that the clock might have been running too fast initially, so as the rate slows the accuracy improves. I have such a clock; I deliberately have it gaining slightly when fully wound so that it only loses slightly later on.
Likes hutchphd
Do you have it from the 70-80s era?
So your clock tells the time accurately only once between windings. Have you considered stopping it? Then you're guaranteed accurate readings twice a day and you don't have to wind it.
  • Haha
Likes Delta2
When I wind it, it is slightly behind, so then catches up and gets ahead. As the spring unwinds, it slows down and gets behind again. So it‘s right twice per winding… but that's only once a week. It's German, 1920s or earlier.
My Welsh longcase clock, ca. 1750, doesn't have that problem, the motive force being constant. Accurate to within a minute over a week!
Likes hutchphd and Delta2
what if he stops it right at the time its reading becomes accurate?
Related to How does the accuracy of the clock change when the spring stretches?
1. How does the length of the spring affect the accuracy of the clock?
The length of the spring directly affects the accuracy of the clock. As the spring stretches, the tension and force it exerts on the clock mechanism changes, which can cause fluctuations in the timekeeping. This is why it is important to regularly check and adjust the length of the spring to maintain accuracy.
2. Can the accuracy of the clock be affected by the material of the spring?
Yes, the material of the spring can impact the accuracy of the clock. Different materials have different levels of elasticity and can stretch at different rates, which can affect the tension and force on the clock mechanism. It is important to use a high-quality, durable spring to ensure accurate timekeeping.
3. How often should the spring be replaced to maintain accuracy?
The frequency of spring replacement depends on the quality of the spring and how often the clock is used. In general, it is recommended to replace the spring every 2-3 years to ensure optimal accuracy. However, if you notice significant changes in the timekeeping, it may be necessary to replace the spring sooner.
4. Can environmental factors affect the accuracy of the clock?
Yes, environmental factors such as temperature and humidity can impact the accuracy of the clock. Extreme temperatures can cause the spring to expand or contract, affecting its length and tension. High humidity can also cause the spring to rust, which can affect its elasticity. It is important to keep the clock in a stable, moderate environment for optimal accuracy.
5. Is there a way to adjust the accuracy of the clock if the spring stretches?
Yes, there are ways to adjust the accuracy of the clock if the spring stretches. Some clocks have a mechanism for adjusting the length of the spring, which can be done by turning a key or knob. If your clock does not have this feature, a professional clock technician can make the necessary adjustments to ensure accurate timekeeping.
  • Classical Physics
9K
