- #36
- 18,994
- 14,470
Nicely done. Thanks for posting.Jorrie said:When I first studied modern cosmology (around Y2K), I made the following plot in an attempt to understand the "whole of expansion"...
The problem with "that solution" may be the "growing" of space. It is really only distances between comoving observers that grows.nikkkom said:And after each second distance between each particle increases by 1 meter. Not because they move, but because space "grows". That's that solution.
I think on this forum we have concluded that we should rather speak of expansion rate H(t) (not expansion speed) as a constant during exponential growth of distances (like a constant % per unit time). Marcus had a lengthy thread on that.nikkkom said:For example, one microsecond after it test particles were 1 microsecond apart. It's a bit curious that in this scenario expansion seems to be very fast at first ("density" of test particles falls very quickly), and millions of years later, it looks very gradual, but expansion speed is in fact constant!
Jorrie said:It is a good starting point, nikkkom, but I spot a few terminology issues:
I'm not sure if these words are compatible with metric expansion, whereby the scale of space itself changes, which I think is the concept that we should convey. How to do this using common words is a difficulty that all layman's treatments face.nikkkom said:... Hence, I choose different wording, not "distance is growing" but "space is growing".
Jorrie said:The problem with "that solution" may be the "growing" of space. It is really only distances between comoving observers that grows.
Jorrie said:I'm not sure if these words are compatible with metric expansion, whereby the scale of space itself changes, which I think is the concept that we should convey. How to do this using common words is a difficulty that all layman's treatments face.
Maybe we can say that each infinitesimal volume of space is 'growing' as scale increases and thus the proper distance between comoving observers increases?
Metric expansion does exactly that (in the cosmos we live in, at least). The most remote observed regions of space (where the presently observed CMB radiation originated) recede from us at over 3c (calculated from the redshift of over 1000). In other words, if there happened to be a comoving object there, its recession speed (or rather recession rate) in terms of dD/dt would have exceeded 3c, where D is the proper distance to the object and t is cosmic time. But, there is no 'force' necessary to do that - it is essentially spacetime curvature that causes the recession.rede96 said:This in layman's language would seem to contradict your statement that it is really only distances between commoving observers that grows, as that implies that it is possible for some 'force' to eventually be separating them at speeds greater than 2c.
nikkkom said:In Minkowski space (i.e. no space expansion), you can't have an infinite cubic grid of observers 1 l.y. apart, moving so that grid increases by 1 m/s - you'll need some observers to move faster than light, which is not allowed.
nikkkom said:Will that be possible in a non-empty Universe (i.e. to model ours)?
Jorrie said:In other words, if there happened to be a comoving object there, its recession speed (or rather recession rate) in terms of dD/dt would have exceeded 3c, where D is the proper distance to the object and t is cosmic time. But, there is no 'force' necessary to do that - it is essentially spacetime curvature that causes the recession.
rede96 said:Dark energy does exert a force. What I mean by that is that all matter (or the space between particles) very slightly expands
until it reaches a new state of equilibrium due to dark energy.
So the universe may 'expand' due to the curvature of spacetime
(although we don't know for sure if space is flat or not)
Moreover the amount dark energy density doesn't dilute as space expands.
There was an initial period of inflation that was caused by some 'energy' field, but this energy field is not dark matter as all that energy was dissipated during inflation, which led to re-heating (big bang) and the first matter being formed.
nikkkom said:no. It will expand, faster, and faster, forever. No equilibrium.
nikkkom said:Wrong terminology. space expansion IS a form of curved spacetime - non-curved one would not expand or contract.
nikkkom said:yes.
rede96 said:What I mean by that is that all matter (or the space between particles) very slightly expands until it reaches a new state of equilibrium due to dark energy.
I think there may be some confusion between two aspects of expansion here. Just like gravity is not a force in GR, dark energy is not a force, because comoving observers are all in free-fall. The only force is of tidal nature and matter with significant size experience stretch/squeeze forces that work against the forces that hold them together. For instance, the sizes of gravitationally bound clusters should stabilize at a size slightly larger than what it would have without dark energy.nikkkom said:no. It will expand, faster, and faster, forever. No equilibrium.
Then there remains two possibilities. Either everything you read was incorrect or your interpretation of it was. The accelerated expansion of the universe is not about the effect of the dark energy on the matter it contains, it is an effect of the dark energy on the space-time itself. Even if there was no matter in the universe, dark energy would lead to accelerated expansion.rede96 said:I meant that there is pressure from dark energy that acts in a very minute way on all mater which, causing it to expand very slightly. So a meter stick is just slightly longer due to dark energy than it would be without it. I am sure that part is correct, well at least according to everything I have read on it.
rede96 said:I need to read up a bit more on this, I get confused between what is physically space and what is spacetime.
Orodruin said:Then there remains two possibilities. Either everything you read was incorrect or your interpretation of it was.
Orodruin said:The accelerated expansion of the universe is not about the effect of the dark energy on the matter it contains, it is an effect of the dark energy on the space-time itself. Even if there was no matter in the universe, dark energy would lead to accelerated expansion.
A meter stick is a whole other issue, it is generally being held together by other forces which at short distances overcome expansion by a lot.
Fine, but this effect is even smaller than the stick's self-gravity. Locally, the presence of the stick will be sufficient for space to not undergo accelerated expansion. Dark energy dominates at large scales only.rede96 said:The forces that hold a meter stick together would obviously be far greater than this very small dark energy force, but it still produces an effect on the meter stick.
Jorrie said:I think there may be some confusion between two aspects of expansion here. Just like gravity is not a force in GR, dark energy is not a force, because comoving observers are all in free-fall.
For the present epoch, essentially yes to all. But, like in all free-fall, it is only a coordinate acceleration, i.e. it depends on the coordinates chosen. E.g. in comoving coordinates, comoving galaxies do not move away from one another, so there can be no acceleration involved. It is thus not acceleration like when a rocket is firing, where we can observe proper acceleration, independent from coordinates choices. This is the type of acceleration that a simple accelerometer will show up.rede96 said:So would it be correct to say that due to GR, all co-moving observers which are not gravitationally bound are in free fall but just away from each other? Also that they accelerate away from each other just as a ball rolling down a hill accelerates? But it is dark energy that causes this 'rate' of acceleration to increase?
Jorrie said:The other fact that you seem to have missed is that 'dark energy', 'vacuum energy' and the 'cosmological constant' are not equivalent
nikkkom said:I think we need a FAQ (pinned post?) which explains all this in some very understandable-for-layman way.
Here's my attempt.
The "ordinary Big Bang and expansion" (no inflation, no dark energy):
Einstein's GR allows a solution (FLRW metric) where an empty Universe expands. Imagine that you have particles (say, hydrogen atoms) in a cubic grid with exactly 1 light year between nearest particles. (We assume that they weigh so little that this Universe is essentially behaves as if it is empty). And after each second distance between each particle increases by 1 meter. Not because they move, but because space "grows". That's that solution.
Even though empty Universe is expanding without slowing (distance between test particles grow by exactly one meter per sec), note that if you look back into the past of this Universe there were times when test particles were much closer together - say, only a billion km apart - and they moved away at exactly one meter per sec too. It's clear there was a moment where they had to be zero meters apart. That's "Big Bang" moment. The moment itself is problematic (singularity!), but any moment after that is not. For example, one microsecond after it test particles were 1 microsecond apart. It's a bit curious that in this scenario expansion seems to be very fast at first ("density" of test particles falls very quickly), and millions of years later, it looks very gradual, but expansion speed is in fact constant!
Now, if you use GR with Λ > 0, the picture changes. Grid of test particles grows not by exactly one meter per sec! Now it grows faster with time. If Λ is very small, at first speedup is not noticeable, but later it will be: test particles will not only move away from each other, they will seemingly do that faster with time.
That's one possibility what dark energy is - maybe it's just Λ. However GR with Λ = 0 but with some other field permeating all space and having appropriate property (negative pressure) will have exactly the same behavior.
How presence of matter changes this? FLRW metric with homogeneous distribution of matter will expand too, but expansion will slow down. (Heuristically, "matter will attract itself and try to shrink the Universe"). If there are lots of matter, expansion speed can even go to zero and start going backwards. Between "too little matter, eternal expansion with nonzero speed" and "too much matter, expansion stops" there is a borderline case where expansion never stops, but its speed falls ever lower, tending to zero with time, but never reaching it (that's "critical density Universe"). This all was about "normal" matter, with positive pressure. With "negative pressure matter" it's effect is opposite - this was already describe in the previous paragraph - that's "dark energy".
And finally, what if dark energy field is variable (e.g. it has several possible stable values) and one of these value is large (or there may be several such fields)? Alternatively, what if Λ can not only be larger than zero, but can be VERY MUCH larger than zero? Nothing unusual will happen, the Universe will behave as described above: grid of test particles grows faster with time. Very, very much faster. That's inflation. (If you have a separate "big dark energy field" for it, that's "inflaton field").
If you have inflationary Universe, even with matter, it expands astoundingly quickly, essentially becoming empty. And if then suddenly Λ (or dark energy) goes down to a very small value, you get an empty symmetrical flat expanding Universe. If "Λ going down" releases energy (in a form of appearance of new particles everywhere), you get a NON-empty symmetrical flat expanding Universe.
rede96 said:So do you know why he would refer to them as all being the same?
Hiphinds said:Hilbert's Hote
Puppy said:Hi
I love this paradox.
But truth be told its nonsensical.
It describes nothing other than infinity is equal to infinity...
I could be wrong?
Yes, you are wrong to think it is nonsensical. As Drakkith says, it is a way of helping people understand infinity. There is nothing nonsensical about it, it simply addresses the fact that infinity does not fit well without preconceived notions of how numbers should work because it ISN'T a number. If you don't understand that, give it time. You'll get it eventually.Puppy said:Hi
I could be wrong?
Orodruin said:Of course, it may be better to avoid using the word "moving" at all.
(2):Orodruin said:A meter stick is a whole other issue, it is generally being held together by other forces which at short distances overcome expansion by a lot.
Orodruin said:Fine, but this effect is even smaller than the stick's self-gravity. Locally, the presence of the stick will be sufficient for space to not undergo accelerated expansion. Dark energy dominates at large scales only.
Micheth said:if the forces (in the case of the ruler, electromagnetic rather than gravitational) are overcoming the expansion, to me that implies that the forces must actually be a smidgen greater than what we calculate them to be (since we calculate the forces assuming molecules to be "at rest" with one another, by which I only mean not being activately separated by universal expansion).
PeterDonis said:Universal expansion in itself doesn't "actively separate" anything; it doesn't exert any force.
Dark energy does cause a very, very, very tiny force that acts to try to separate the atoms in a ruler; but I emphasize very, very, very tiny. Much smaller even than a "smidgen". But dark energy corresponds to accelerating expansion, not just expansion.
Micheth said:the resulting situation is such that object A and object B are caused to be further from each other than they would have been without the expansion.
That's what I was referring to, that needs to be "overcome" by intermolecular (or gravitational) forces. Not a force, but the increased distance between A and B.
PeterDonis said:And the point I'm making is that anything that has to be "overcome" by intermolecular or gravitational forces is a force. Saying that A and B "are caused to be further from each other" is just a confusing way of describing a force; it isn't something different.
To put it another way: what matters isn't the words, it's the physics, and the physics is that there is nothing due to "expansion" (if we leave out dark energy) that needs to be "overcome" by the forces that hold bound systems together. Not a "force", not "increased distance", not "creation of more space"--nothing.
Micheth said:I thought "being further from each other" is exactly the point of universal expansion?
Micheth said:Given (non-gravitationally/force-bound) entities A and B, let the universe expand another XX million years and it will then take me X amount of time longer to go from A to B than it does today.
