How Does the Jones Matrix Explain Light Polarization with Quarter Wave Plates?
  • Thread starter Thread starter yklin_tux
    Matrix
The discussion focuses on the application of the Jones matrix to explain light polarization when using a quarter wave plate (QWP). It highlights that when vertically polarized light passes through a QWP with a horizontal fast axis, the resultant polarization appears as (0, -i), which some participants interpret as equivalent to the original vertical polarization state (0, 1). The conversation emphasizes that if the light's polarization aligns with the fast or slow axis of the QWP, there should be no change in polarization. Additionally, it is noted that the change in the polarization state can be represented as a multiplication by an arbitrary phase factor, which does not affect the overall polarization. The participants express agreement on these interpretations, reinforcing their understanding of the Jones matrix's role in light polarization.
yklin_tux
Hello, I am wondering a little about Jones matrix...
For example, If I have a Quarter Wave Plate with fast axis Horizontal, given by matrix
1 0
0 -i
and a vertically polarized light
the resultant light polarization is
-i
With QWP, it makes sense that if the direction of light polarization is the same as the direction of the fast, or the slow axis, then it does not make sense that the transmitted light is polarized at all, because there aren't electric field components changing phase.
So - is it ok to interpret that
-i
which is the resultant polarization of horizontally polarized light going through a QWP which has
fast axis also horizontal
is the same as
that is the only reasonable explanation to me thus far because nothing should happen to the polarization of light, yet the intuitive answer is different from the jones matrix one
I think you made an error- I got the resultant polarization for horizontally polarized light through a QWP (fast axis horizontal) as (1,0).
Thus, the vertical polarization is retarded by a quarter wave with respect to the horizontal- in order to convert linear polarization to circular, orient the fast axis at 45 degrees to the incident polarization state.
For a QWP, if the incident polarisation is oriented along the fast or slow axis, then there will be no change in the polarisation state.
The change from (0 1)' to (0 -i)' is not regarded as a change in the polarisation state, as you can multiply through by an arbitrary phase factor to retrieve the original (0 1)' state.
Claude.
Claude, I agree.
If I have a phase factor of e^i(pi/2) then I will just get
E = 0 ihat + E0 * -i*e^i(pi/2) jhat
= 0 ihat + E0 * 1 jhat which is what I began with
Correct me if I am wrong! but it makes sense to me as of now!
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
