How Does the Law of Conservation of Momentum Apply in a Firework Explosion?
  • Thread starter Thread starter sumitmanhas
    Explosion Momentum
The discussion centers on the application of the law of conservation of momentum in a firework explosion scenario. The initial momentum of the "egg" is zero since it is at rest before the explosion. After the explosion, the two pieces move in opposite directions, maintaining the total momentum at zero. The forces between the two pieces during the explosion are equal, in accordance with Newton's third law of motion. This reinforces the principle that momentum is conserved in the system.
sumitmanhas
A giant "egg" explodes as part of a fireworks display. The egg is at rest before the explosion, and after the explosion, it breaks into two pieces, with the masses indicated in the diagram, traveling in opposite directions.
Part A
What is the momentum PA,i of piece A before the explosion?(initial momentum)
Part B
During the explosion, is the force of piece A on piece B greater than, less than, or equal to the force of piece B on piece A?
part a
i think as it says in the question that the egg is at rest so won't the initial momentum be zero but a bit hesitant ...cant be that easy...
part b
equal forces according to Newtons law ?
That's right! just set it up lie that and remmber since they go in opposite directions, one is negative so
0 = m1v1-m2v2
THANKS aimslin 22 for givin positive resp
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
