MHB How Does the Law of Cosines Prove a Triangle's Angle and Side Relationships?
  • Thread starter Thread starter Albert1
The discussion focuses on proving the relationship between the sides and angles of triangle ABC, given that the sum of angles A and C equals twice angle B. The proof begins by establishing the equation involving the sides a, b, and c, leading to the relationship b² = a² + c² - ac. By applying the sine rule, it is shown that sin²B equals sin²A plus sin²C minus sin A sin C. The conclusion confirms that angle B is 60 degrees, validating the derived relationships through the law of cosines and sine. This establishes a clear connection between the triangle's angles and side lengths.
Albert1
$\triangle ABC (with \,\,side \,\,length \,\, a,b,c), \,\, given :\angle A+\angle C =2 \angle B $
prove :
$\dfrac {1}{a+b}+\dfrac{1}{b+c}=\dfrac {3}{a+b+c}$
Mathematics news on Phys.org
[sp]\begin{array}{rcl}\dfrac {1}{a+b}+\dfrac{1}{b+c}=\dfrac {3}{a+b+c} & \Longleftrightarrow & (a+2b+c)(a+b+c) = 3(a+b)(a+c) \\ & \Longleftrightarrow & a^2+b^2+c^2 + 3ab + 3bc + 2ac = 3b^2 + 3ab + 3bc + 3ac \\ & \Longleftrightarrow & b^2 = a^2 + c^2 - ac. \end{array}
Next, by the sine rule, $a,b,c$ are proportional to $\sin A,\sin B,\sin C$, so it will be sufficient to prove that $\sin^2B = \sin^2A + \sin^2C - \sin A\sin C.$
Also, we are told that $\angle A+\angle C =2 \angle B .$ But $\angle A+\angle C = 180^\circ - \angle B$, so that $3\angle B = 180^\circ$, $\angle B = 60^\circ$, and so $\sin^2 B = 3/4.$ And $\angle C = 120^\circ - \angle A$, so $\sin C = \sin120^\circ \cos A - \cos120^\circ \sin A = \frac{\sqrt3}2\cos A + \frac12\sin A.$ Therefore $$\begin{aligned}\sin^2A + \sin^2C - \sin A\sin C &= \sin^2A + \tfrac14(\sqrt3\cos A + \sin A)^2 - \tfrac12\sin A(\sqrt3\cos A + \sin A) \\ &= \sin^2A + \tfrac14(3\cos^2 A + 2\sqrt3\sin A\cos A + \sin^2 A) - \tfrac12\sin A(\sqrt3\cos A + \sin A) \\ &= \tfrac34\sin^2 A + \tfrac34\cos^2 A = \tfrac34 = \sin^2 B,\end{aligned}$$ as required.[/sp]
Couldn't you use use the law of Cosine with $\angle B = 60^\circ$ to get to the same answer quicker?
(Tongueout)
from Opalg's solution :
$b^2 = a^2 + c^2 - ac.$--------(1)
as jester said "Couldn't you use the law of Cosine with [FONT=MathJax_Main]∠[FONT=MathJax_Math]B[FONT=MathJax_Main]=[FONT=MathJax_Main]60[FONT=MathJax_Main]∘ to get to the same answer quicker?"
using law of Cosine :
$b^2=a^2+c^2-2ac\,\, cos B-------(2)$
compare (1) abd (2)
if (1)=(2) then $cos B=\dfrac {1}{2},\,\, \,\,now\,\, we\,\,\,only\,\, have\,\, to \,\, prove : \angle B=60^o$
$using :\angle A+\angle C=2\angle B,\therefore\,\, 3\angle B=180^o \Longleftrightarrow \angle B=60^0$
and the proof is finished
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
