How does the n drop down in this recurrence relation problem?
The discussion centers on understanding how the variable 'n' transitions in a recurrence relation problem. The base case is established as 2^k = n, leading to k = log_2(n). The confusion arises when trying to relate the summation involving k to a form that includes n. By substituting k with log_2(n) in the expression (7/4)^k, the 'n' effectively appears in the exponent, clarifying its presence in the final equation. The key takeaway is that the relationship between k and n is crucial for resolving the transition in the recurrence relation.
seansrk
[PLAIN]http://img442.imageshack.us/img442/4514/ballsp.jpg
The base case is 2^{K} = n (which turns into log_{2}n = k
So I have a question on this recurrence relation problem. (I'm trying to get to make the top equation look like the bottom equation.) I know that the summation ends up becoming
\frac{((7/4)^K)-1}{(7/4)-1}
which gives us
((7/4)^log_{2}n)-1 / (3/4)
I'm lost on how the n drops down. I know how the (log[2]7-2)-1 comes to be but how does the n and log[2]7 -2 get on the same level and the exponent level disappeared?
Hopefully I didn't make this confusing. Just trying to find out how the n came down.
Mathematics news on Phys.org
Your basic problem is that the first sum depends upon the value of "k" but there is no "k" in the second. What happened to it? And, since there is no "n" in the sum (ignore the "n^2" for the moment), how do you get that "n" in the numerator of the second formula?
Well previously in the problem it was stated that 2^k = n. Which using the rules of logs we turned that into k = log base 2 n. So when we got the (7/4)^k what I did was i substituted log base 2 n into k giving us the n. in the exponent.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
