How does the OpAmp bypass Vf limitations in precision rectifiers?
OpAmps in precision rectifiers effectively bypass the forward voltage (Vf) limitations of standard rectifiers by supplying the necessary voltage to keep the diode conducting. When the input voltage (V_in) is low, the OpAmp maintains a higher output voltage, ensuring the diode remains "on" even for small signals that do not exceed 0.7 volts. The output of the OpAmp is not the final output of the circuit; instead, it is adjusted to provide the required voltage difference. This unique property of OpAmps makes precision rectifiers particularly useful for small signal applications. Understanding this mechanism is crucial for effectively utilizing OpAmps in rectification circuits.
Rusag
Hi all,
I am currently studying OpAmps and one of the topics that came up was the applications of OpAmp circuits. In particular, I was learning about precision rectifiers (using non-inverting version of it, thus the diode is pointing away from the "out" terminal of the OpAmp). The thing I cannot figure out is how does the OpAmp bypass the Vf limitations that regular full bridge rectifiers face. In other words, say for V_in = 0, the voltage at the inverting terminal is close to 0 as we assume an ideal device. Therefore, the voltage at the output terminal is 0.7 volts higher than that of the inverting input. My assumption is that if V_in remains at 0, the voltage at the output terminal will stay at 0.7 volts.
To summarize the question, what properties of the OpAmp cause it to create and sustain that voltage difference that keeps the diode "on". Isn't it just easier for the OpAmp to establish 0 volts at the output and thus 0 volts at the inverting input node?
My wording of the question could be confusing as I am trying to learn rather than stating something I know. But I came across this concept multiple times - that the voltage required to turn on the diode is supplied by the OpAmp rather than by the small signal. That is the reason why the precision rectifier is so useful for small signals that barely or don't at all exceed 0.7 volts
And that's true. When you examine the circuit you can see that the output of the OP-AMP is not the point from which we take the output of the circuit. http://en.m.wikipedia.org/wiki/Precision_rectifier
The OP-AMP output will be 0.7V more than the voltage we desire, but we don't take our rectified output from the OP-AMP output pin.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
