MHB How does the population of a southern city follow the exponential law?
The population of a southern city follows the exponential growth model, expressed as N(t) = N_0e^{kt}. Given that the population doubled in 18 months and is currently 10,000, the growth constant k is approximately 0.462098. Using this value, the projected population in two years is approximately 25,198. A suggestion was made to clarify the equation setup for better understanding, but it was acknowledged as a minor point. The calculations and logic presented were deemed correct overall.
karush
MHB
$\tiny{\textbf{6.8.7}}$ Kiaser HS
Population Growth The population of a southern city follows the exponential law
(a) If N is the population of the city and t is the time in years, express N as a function of t.$N(t)=N_0e^{kt}$
(b) If the population doubled in size over an 18-month period and the current population is 10,000, what will
the population be 2 years from now?
$\begin{array}{rl}
2&=e^{k(1.5)} \\
\ln 2&=k \cdot 1.5\\
\dfrac{\ln 2}{1.5}&=k\\
\therefore k&\approx0.462098\\
f(t)&\approx10000e^{0.462098\cdot 2}\\
&\approx 25198
\end{array}$
well anyway hopefully ok :unsure:
typos maybe
Mathematics news on Phys.org
I didn't check the numbers but the logic is correct.
-Dan
Since you stated your basic equation as
$N(t)= N_oe^{kt}$
I would have preferred that you write
$2N_0= N_0e^{1.5k}$
before you divide both sides by $N_0$ to get
$2= e^{1.5k}$.
But I realize that is being petty!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
