How Does Trigonometric Substitution Simplify the Integral Calculation?
In summary, the conversation discusses finding the integral $I_{49}$, which involves using a substitution and an identity to simplify the integral. The final result is $\frac{\pi}{2}$ and the domain of the integral is from $0$ to $\frac{\pi}{2}$.
karush
MHB
3,269
$a=0 \ \ b=12$
$\displaystyle I_{49}=\int_{a}^{b} \frac{dx}{\sqrt[]{144-x^2}} \, dx = \arcsin{\left[\frac{1}{12}\right]} \\$
$ \text{use identity} $
$\sin^2\theta+\cos^2\theta = 1
\Rightarrow 1-\cos^2\theta=\sin^2\theta
$\text{x substituion} $
$\displaystyle
x=12\sin{\theta}
\therefore dx=12\cos{\theta}
\therefore \theta=\arcsin\left[\frac{x}{12}\right]
$\displaystyle I_{49}=\int_{a}^{b} \frac{12\cos {\theta}}{\sqrt[]{144-144cos^2\theta}} \, d\theta
= \int_{a}^{b} \frac{\cos\theta}{\cos{\theta} }\, d\theta =
\int_{a}^{b} 1 \,d\theta = \left[\theta\right]_a^b
$\text{back substitute } \\
\displaystyle
a=0 \ \ b=12 \ \ \theta=\arcsin\left[\frac{x}{12}\right]$
$\arcsin\left[\frac{12}{12}\right]
-\arcsin\left[\frac{0}{12}\right]=\frac{\pi}{2}$
Here's how I'd work this problem:
\(\displaystyle I=\int_{0}^{12}\frac{1}{\sqrt{12^2-x^2}}\,dx\)
Let:
\(\displaystyle x=12\sin(\theta)\implies dx=12\cos(\theta)\,d\theta\)
\(\displaystyle I=\int_{0}^{\frac{\pi}{2}}\,d\theta=\frac{\pi}{2}\)
Ok, after drying my years
Why would the domain be $0$ to $\frac{\pi}{2}$ ?
Originally, the limits were in terms of $x$, but with the substitution were using, we need them to be in terms of $\theta$. So we use:
\(\displaystyle \theta(x)=\arcsin\left(\frac{x}{12}\right)\)
So, we find the new limits to be:
\(\displaystyle \theta(0)=\arcsin\left(\frac{0}{12}\right)=0\)
\(\displaystyle \theta(12)=\arcsin\left(\frac{12}{12}\right)=\frac{\pi}{2}\)
Ok got it:cool:
The only real issue I would find with what you originally posted is this line:
\(\displaystyle I_{49}=\int_{a}^{b} \frac{dx}{\sqrt{144-x^2}}\,dx=\arcsin\left(\frac{1}{12}\right)\)
You have two differentials in the integral, and the result should be:
\(\displaystyle I_{49}=\int_{a}^{b} \frac{1}{\sqrt{144-x^2}}\,dx=\arcsin\left(\frac{b}{12}\right)-\arcsin\left(\frac{a}{12}\right)\)
FAQ: How Does Trigonometric Substitution Simplify the Integral Calculation?
What is a trig substitution?
A trig substitution is a method used in calculus to simplify integrals involving trigonometric functions. It involves substituting a trigonometric expression for a variable in an integral to make it easier to solve.
Why is a trig substitution useful?
Trig substitutions are useful because they allow us to solve integrals that would otherwise be difficult or impossible to solve. They also help to simplify complex integrals and make them more manageable.
How do you know when to use a trig substitution?
Generally, a trig substitution is used when the integral involves a square root of a quadratic expression containing a sum or difference of squares of a variable and a constant. This can also be identified by looking for terms in the integral that can be rewritten as a trigonometric identity.
What are the common trigonometric substitutions?
The most common trigonometric substitutions are:
- x = a sinθ
- x = a cosθ
- x = a tanθ
Are there any limitations to using a trig substitution?
Yes, there are limitations to using a trig substitution. It can only be used when the integral involves a square root of a quadratic expression containing a sum or difference of squares of a variable and a constant. It also may not work for all integrals, and in some cases, other methods may be more effective.
