How Does Water Affect the Angle of Diffraction for Light Through a Single Slit?
  • Thread starter Thread starter whiteman
    Diffraction Water
The discussion focuses on calculating the angle of diffraction for light passing through a single slit when immersed in water. The wavelength of light is 676 nm, and the slit width is 1.60 × 10^-5 m. The correct formula for the angle of the dark fringe is identified as sin(θ) = m(λ)/d, rather than using m + 1/2. After recalculating, the angle θ for the third dark fringe is determined to be approximately 6.38 degrees. The importance of using the correct diffraction formula is emphasized for accurate results.
whiteman
Light of wavelength 676 nm in vacuum is incident on a single slit whose width is 1.60 × 10-5 m. The setup is then immersed in water whose index of refraction is 1.33. What is the angle θ that locates the third dark fringe with respect to the central bright fringe?
1. sin\alpha = (m +1/2)\lambda/d
where \alpha is the angle of diffraction, \lambda is the wavelength, and d is the width of the slit
2. sin\anglei / sin\angler = n
where i is the angle of incidence, r is the angle of refraction, and n is the refractive index
sin\alpha = (3 + 1/2)(676)(10^-9)/(1.6)/(10^-5)
sin\alpha = .147875
\alpha = 8.5037997
sin\alpha = sin\anglei ( i presume, so...)
.147875/sin\angler = 1.33
sin\angler = .11118421
\angler = 6.383584609
i'm not sure is theta = \angler
i figured it out. i was using the wrong formula for diffraction. instead of m + 1/2, i should have been using m
sin(theta) = m(lambda)/(d) instead of m+1/2
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
