How Does Wood Resistance Affect Bullet Penetration and Stoppage Time?
The discussion centers on calculating the resistive force exerted by wood on a bullet and the time it takes for the bullet to come to rest after penetrating the wood. The resistive force was confirmed to be 4700 N, leading to an acceleration of -471154 m/s². The time for the bullet to stop after entering the wood was calculated as approximately 0.000743 seconds. There is confusion regarding the relevance of the time spent in the barrel, with some participants questioning whether it affects the overall stopping time. Ultimately, the focus is on understanding the dynamics of bullet penetration and the impact of wood resistance.
TylerK
A rifle with a barrel length of 56 cm fires a 10 g bullet with a horizontal speed of 350 m/s. The bullet strikes a block of wood locked in position and penetrates to a depth of 13 cm.
What resistive force (assumed to be constant) does the wood exert on the bullet?
How long does it take the bullet to come to rest?
f = m * a
d = v * t
vf = vi + a * t
Force of wood on bullet = 4700 (was confirmed correct)
f = m * a
a = -471154 N
I tried
D = v * t1 for the barrel
.55 = 350 * t1
t1 = 350 / .55 = .0016 seconds
For the wood
vf = vi + a * t2
0 = 350 - 471154 t2
t2 = 350 / 471154 = .000743 seconds
t1 + t2 = .002343 seconds which is wrong.
If the barrel was twice longer, would it change time needed to stop the bullet?
You wrote
TylerK said:
a = -471154 N
Are you sure N is a correct unit of acceleration?
Yes it is m/s^2 I mistakenly typed N. I tried to brake the problem up into 2 parts.
Part 1: Time of bullet in barrel, with 0 acceleration so
d = v * t
.56m = 350 m / s * t
t = .56 m * s / 350 m = .0016 seconds
Part 2: Time it enters the wood until the bullet stops.
vf =vi + a * t
0 = 350 m/s + (-471154 m / s^2) t
-350 m/s * (1/-471154 m/s^2) = t
t = .000743 seconds
I apparently do not add these 2 times together, as the combined result is incorrect.
If the barrel was twice as long, wouldn't it double the amount of time the bullet was in the barrel, as accounted for in the first part? (assuming no friction in the barrel)
You are missing the point.
Is the time spent in the barrel in any way relevant?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
