MHB How far above the ground is the tack?
  • Thread starter Thread starter veronica1999
    Ground
Devon's bike has 27-inch diameter wheels, and after rolling 100 feet, he stops with a tack picked up by the front wheel. The circumference of the tire is approximately 84.82 inches, leading to a total distance traveled of 1200 inches, resulting in about 14.147 revolutions. A miscalculation initially led to an incorrect angle and height above the ground for the tack. The correct calculations reveal that the tack is approximately 5.368 inches above the ground after accounting for the wheel's rotation.
veronica1999
Devon's bike has wheels that are 27 inches in diameter. After the front wheel picks up a tack, Devon rolls another 100 feet and stops. How far above the ground is the tack?
I did all my work carefully but the answer seems wierd.
circumference of tire :84.78 inches
total distance traveled is 1200 inches
1200 /84.78 = 14.154
84.78 : 0.154 = 360: X
X = 0.653
13.5cos0.653 = 13.4991
13.5 - 13.4991 = 0.000876
answer : 0.000876
Mathematics news on Phys.org
First, it would help to use more digits of pi. Then 1200/(27$\pi$)=14.147 up to 3 decimal digits.
This should be X / 360 = 0.147 (this is a fraction of the full circle). Then X = 52.958 degrees and the final answer is 5.368 inches.
Thank you! :D
Now I see my mistake.
Instead of 84.78 : 0.154 = 360 : X
the equation should have been 84.78 :13.056 = 360 :X
X = 55.4
1200/27pi = 14.147
84.78 : 12.46 = 360 :X
x= 52.958
Hello, veronica1999!
I did all my work carefully but the answer seems weird.
Circumference of tire: 84.78 inches . This is wrong.
Total distance traveled is 1200 inches
1200 / 84.78 = 14.154
84.78 : 0.154 = 360 : X . This is wrong, too.
X = 0.653 . That is a VERY small angle, isn't it?
Answer: 0.000876
$\text{Circumference: }\:27\pi \:\approx\:84.82 $
$ \text{Then: }\:\dfrac{1200}{84.82} \:=\:14.1476\text{ revolutions} $
$\text{The wheel makes 14 revolutions and a fraction of a revolution.}$
$\text{That fraction is: }\:0.1476 \times 360^o \:=\:53.136^o $
$\text{Got it?} $
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
