How Far Are the Cosmic Ray and Photon at t=0s According to the Observer?
The discussion centers on calculating the distance between a cosmic ray and a photon at t=0s as observed from a specific point in the Milky Way. It is noted that the cosmic ray has a gamma factor of 10^10, and the photon passes the observer at t2=1.33x10^-8 seconds. Participants express confusion about the application of special relativity, suggesting that the distance can simply be calculated as ct2, given the observer's perspective. However, it is acknowledged that while relativity may not be necessary for this specific calculation, subsequent parts of the problem may involve relativistic effects due to the galaxy's movement. The conversation highlights the importance of understanding both classical and relativistic concepts in astrophysical scenarios.
roman15
A cosmic ray of gamma=10^10 is chased across the Milky Way by a photon. The cosmic ray passes an Observer at one edge of the galaxy and t=0s then the photon passes at t2=1.33x10^-8. These times are recorded by the Observer
How far away are the cosmic ray and photon at t=0s according to the observer?
Im not really seeing how to apply special relativity to this, wouldn't the distance between them just be ct2, because its asking according to the observer and from t=0 to t2, the distance traveled by the photon in that time would be the distance between them right?
Right. Relativity is not needed to answer this question. (I suspect that there are followup questions that might require special relativity.)
haha you there are, the next couple of parts of the question deal with the galaxy moving relative to the cosmic ray
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
