How Far Does the Camera Fall Before the Skydiver Catches It?
A skydiver drops a camera and realizes the mistake after 3 seconds, then dives with an initial velocity of 10.0 m/s while the camera falls freely at 9.8 m/s². The diver's acceleration is 8.0 m/s², and the camera falls 44.1 meters in the first 3 seconds. To find when the diver catches the camera, the equations of motion for both must be set equal, leading to a quadratic equation. After solving, the time taken for the diver to catch the camera is determined to be 22 seconds, resulting in a displacement of 644.6 meters. Understanding the steps and equations used is crucial for solving similar physics problems in the future.
  • #31
ok i got it!
now how do i solve for displacement?
  • #32
Remember that y is your displacement. What did you do by solving your quadratic?
  • #33
i solved for time, a little differently then your formula, check the link in one of my above posts.
  • #34
And so, where are you now in your problem?
  • #35
I need displacement given the time it took for the diver to reach the camera.
  • #36
Didn't you say you had all solved for (obviously except displacement)?
y=delta-d(displacement)
  • #37
yes thank you, i just realized i can now sub in my time in each of the motion equations, the camera and diver.
  • #38
can you explaint this formula please? i thought y=displacement? lol
  • #39
Sorry... I haven't bothered with LaTeX yet, basically what I typed was y=displacement, since the symbol for displacement is delta-d. Djeit's derivation had a mistake in it, try:
<br /> (v_{i1}-v_{i2})t+\frac{1}{2}(a_{1}-a_{2})t^{2}=0<br />
  • #40
Hey I'm so sorry about my quadratic equation :S it was supposed to be (v_{i1}-v_{i2})t+\frac{1}{2}(a_{1}-a_{2})t^{2}=0
  • #41
oh ok thank you guys very much
the original screwed me up so bad lol
  • #42
Since it's for your class, you should be able to do this yourself. Make sure you get a lot of practice, test time won't let you use PF:smile:
All we did was simply group the like terms together. Make sure you're comfortable with this, because a question like this is bound to be on one of your tests. (From experience)
Regards,
Fragment
  • #43
haha you're right. And yes there may be one of these, for the most part we are doing slightly less difficult ones, without the 3 second start difference.
  • #44
what answer did you get with the corrected quadratic?
i think you guys are missing the fact that the camera was falling for 3 seconds already and traveled 44.1 m...and neither of those numbers appeared in the quadratic...wow I am nowhere near close to finishing this lol
  • #45
I don't think I'm allowed to post an answer until you have first, that way I don't give out an easy solution. Did you manage to figure it out yourself?
Regards,
Fragment
  • #46
i don't see why it would hurt, I would only gain from it.
but anyways, i got a time of 50 s from the quadratic, and need displacement still :(
im doing something wrong
  • #47
Can you post your work so we can see where you went wrong? 50s is not correct. It would be very helpful:smile:
Fragment
  • #48
I don't know how to do those fancy equations so, this is the best i can do
(0-10)t + 1/2 (9.8-8)t^2=0
-10t + 0.9t^2=0
if you sub that into the quadratic you get 50 or another number if you use the other root...
i also want to know where the 3 second delay of the diver comes into play in these equations...because I am not seeing it
  • #49
Your numbers are wrong, that's why the quadratic gives you 50...
v_1 here is the first velocity of the camera, and you had found that yourself in your first post (29.4), so I don't know how you got 0 there. As for a1 and a2, they are your accelerations of the camera and of the diver, respectively. (9.8 and 8.0). Try again with those numbers.
Fragment
  • #50
wouldnt initial velocity of the camera be 0?
if v1 is 29.4, what's v2?
  • #51
10, since your diver had a velocity of 10.0m/s when he dove out of the plane...
  • #52
ok i see,
v1 should still be 0, as 29.4 was its the cameras final velocity.
I got 22 s
  • #53
That's not your final velocity. You are comparing velocities and accelerations of two objects in free-fall in an attempt to see where they cross. So 29.4m/s is the velocity that your camera had (at 3.0s) when the diver dove from the place. Thus it is clearly v_1. Otherwise, let it be 0, and you will notice that v_2 also needs to be 0. This is where the 3.0s comes into play. I hope you see the logic in this.
Fragment
  • #54
I think I get it, but the diver isn't in free fall...
was 22 s correct?
  • #55
Correct.
  • #56
I don't need to add the 3s?
and to get my displacement, do i use the numbers from the simplified quadratic in the displacement formula?
  • #57
For the 3s, no. You don't need to because as I said, you're comparing the times. Our 22s says it takes 22s of free-fall for the objects to cross paths. The 3s was already accounted for when we supposed that v_1 was 29.4m/s.
For the displacement, you managed to figure out time, and since you know that,
<br /> y=v_{i}t+ \frac{1}{2}at^{2}<br />
You have your answer really, 22s tells you everything. Go ahead and try putting 22s in both y_1 and y_2, see what you get for both displacements...
  • #58
Do you clearly understand everything we have done so far? It was pretty simple; in physics you need to pay good attention to what is happening, and to what numbers to use and where. :smile:
  • #59
ok but like i said, not both objects are in free fall, only the camera..right?
  • #60
What is your diver doing then?
24K
  • · Replies 20 ·
