How Far is the Ship from the Rocks When Sighting a Lighthouse?
The discussion revolves around calculating the distance of a ship from a rocky cliff based on the height of a lighthouse and the angle at which a sailor sights it. The lighthouse is 49 feet tall, with a rocky cliff extending 19 feet from its base, while the sailor's eye level is 14 feet above the water. The initial calculation using the tangent function yields a distance of approximately 60.6 feet, but there is confusion regarding the interpretation of the cliff's extension. Participants agree that the problem's wording is unclear, particularly about the horizontal distance of the rocks from the lighthouse. Clarification of the problem's details is necessary to arrive at the correct answer.
cphill29
A lighthouse that rises 49 ft above the surface of the water sits on a rocky cliff that extends 19 feet from its base. A sailor on the deck of a ship sights the top of the lighthouse at an angle of 30 degrees above the horizontal. If the sailor's eye level is 14 ft above the surface of the water, how far is the ship from the rocks?
tanx=opp/adj
tan30=35/x
xtan30=35
x=35/(tan30)
x=60.6 ft
Since the lighthouse is 49 feet above the surface and the sailor is 14 feet above the surface, the opposite side of the triangle is 35 feet, but I can't get the right answer doing this.
The wording of the problem is not that clear. I believe when saying that ' the rock cliff extends 19 feet from its base ' , that it means that the rocks start 19 feet horizontally away the lighthouse. So your method is correct, just make the necessary adjustment to your answer.
That's what I thought, too, but it gives me a picture and it's clear that is not the case. I did try it though and still got the answer wrong.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
