MHB How Far Will a 30 kg Cart Move in 3 Seconds with a 10 N Push?
A shopper pushes a 30 kg cart with a force of 10 N, resulting in an acceleration of 0.333 m/s². Using the kinematic equation, the cart will move approximately 3 meters in 3 seconds from rest. The discussion raises questions about the notation used, the assumption of constant acceleration, and the neglect of friction. Clarifications on these points could improve the analysis. Overall, the calculations indicate a straightforward application of Newton's second law and kinematics.
karush
MHB
$\tiny{cp 3.6.11}$
$\textsf{A shopper in a supermarket pushes a loaded cart with a horizontal force of 10 N.}$
$\textsf{If the cart has a mass of 30 kg,}$
$\textit{a. how far will it move in 3s starting from rest }$
\begin{align*}\displaystyle
ma&=F \\
a&=\frac{F}{m} \\
&=\frac{10N}{30 \, kg} \\
&=.333 \, m/s^2\\
x&=x_o + v_o t+\frac{1}{2}at^2 \\
&=0+0+(.333 \, m/s^2) \cdot (3 s)^2 \\
&\approx \color{red}{3 \, m}
\end{align*}ok I think this is ok
but the notation could be better
so suggestions
Mathematics news on Phys.org
Thought Questions:
1) Where did the 1/2 go?
2) Are you SURE the acceleration is constant?
3) No friction at all?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
