How Fast Was the Ball Thrown in This Projectile Motion Problem?
The problem involves calculating the initial velocity of a ball thrown at a 30-degree angle, landing on a building 20 meters away and 5 meters higher than the starting point. The solution indicates that the initial speed is 20 m/s. Participants discuss the need to separate the motion into horizontal and vertical components to solve the problem effectively. They suggest using kinematic equations, particularly rearranging v² = u² + 2as, to find the initial velocity. Understanding the angle of projection is crucial for accurate calculations in projectile motion.
Jordan_
A ball is thrown upward at an angle 30 degrees above the horizontal and lands on the top edge of a building 20 m away. The top edge is 5m above the throwing point. How fast was the ball thrown?
ANS 20 m/s.
I just can't seem to get this. It looks like there is a piece of info missing but I know that's not the case. Any hints?
there are enough values to solve this problem
you need to calculate horizontal component and vertical component
have you tried using v2= u2+2as ? I think rearranging that for u should work.
you've got to compute horizontal and vertical component because the ball was not thrown directly upward.. it was thrown at 30 degrees
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
