MHB How Full Is the Larger Bucket After Pouring?
  • Thread starter Thread starter 816318
    Act Fractions
Joseph pours blue paint into two buckets, with the larger bucket being three times the size of the smaller one. After filling, the larger bucket is 3/4 full and the smaller bucket is 1/3 full. The smaller bucket's contents, which amount to 1/9 of the larger bucket's capacity, are then poured into the larger bucket. This results in the larger bucket being filled to 31/36 of its total capacity. The calculations confirm the final volume after the transfer.
816318
Before Joseph paints his house, he pours blue paint into 2 buckets of different sizes. He notices that the volume of the larger bucket is 3 times the volume of the smaller bucket. At the end of the day, Joseph estimates that the larger bucket is 3/4 full and the smaller bucket is 1/3 full/ He decides to pour all of the paint from the smaller bucket into the larger bucket. After that, how full is the larger bucket?
I know the answer is 31/36, but can someone show me how to set it up?
Mathematics news on Phys.org
Re: ACT problem
The smaller bucket is 1/3 the size of the larger bucket, and so if the smaller bucket is 1/3 full, it contains 1/9 the capacity of the larger bucket (since 1/3 of 1/3 is 1/9). So, to determine how full the larger bucket would be if the smaller bucket's contents are added, we need to start with what it already has and add 1/9 to that:
$$F=\frac{3}{4}+\frac{1}{9}$$
Since the two denominators are co-prime (they share no common factors), their LCM is their product and so the LCD is $4\cdot9=36$:
$$F=\frac{3}{4}\cdot\frac{9}{9}+\frac{1}{9}\cdot\frac{4}{4}=\frac{27}{36}+\frac{4}{36}=\frac{27+4}{36}=\frac{31}{36}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
19K
9K
12K
14K
