MHB How have I dropped a factor 2 on the square root of 19?
The discussion centers on a mathematical problem involving the equation derived from a geometric context. The equation simplifies to \(30 = 3x^2 - 18x\), leading to the completion of the square method. The solution yields \(x = 3 \pm \sqrt{19}\). A participant expresses confusion about a supposed missing factor of two on the square root of 19, but another clarifies that no factor was actually dropped. The resolution emphasizes that the calculations are correct as presented.
mathlearn
The main problem is http://mathhelpboards.com/pre-algebra-algebra-2/find-length-dc-19355.html#post88492
In this question
$15 = \dfrac{\left((x+3)+(2x-3)\right)h}{2}=\frac12 ((x+3)+(2x-3))\times((2x-3) -(x+3))=\frac12((2x-3)^2-(x+3)^2)=\frac12(3 x^2-18 x)$
So we get $30=3x^2-18x$
Now using the complete the square method
$x^2-6x=10$
$x^2-6x+9=19$
$x=3\pm\sqrt {19}$
This is what I get , I know that i Have missed a factor of two on the square root of 19, How and why was that dropped?
Mathematics news on Phys.org
You have not.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
