Baluncore
- 10,235
Only one competitor wins each race. I will bet on the favourite, helium. Vacuum balloons have so many issues, they DNS.akhmeteli said:As for helium balloons, they have their own set of issues (don't get me started:-) ). Furthermore, helium balloons are competitors to stratospheric vacuum balloons too.
They can be flown from a slow moving vehicle or a ship. The vehicle can stop when there is some wind.akhmeteli said:I don't know much about gyro kites, but I believe they are wind-dependent.
Untethered balloons do not stay where you release them. Their position is wind dependent, unless they are dirigible.akhmeteli said:And tethered balloons require some real estate, and their altitude is wind-dependent
We have not needed vacuum balloons for those applications before. Instead, we have used lifting gas balloons, that are more available and less fragile than vacuum balloons. I have no problem disagreeing with you on the existence of applications for vacuum balloons. Vacuum balloons will be a novelty, with no application that cannot be met by a helium balloon.akhmeteli said:So you don't think there is any application for low-altitude vacuum balloons. I believe there are some important applications, such as antennas, freight transportation in remote areas, etc., so let us agree to disagree.
There are several companies making and flying stratospheric balloons now, so how hard can hard be? I believe it is hard to make a vacuum balloon, even for sea level.akhmeteli said:And let us not forget that, while making a sea-level balloon is really hard, making a stratospheric balloon is significantly harder.
Internal saturation is important at low altitudes. The molecular weight of dry air is 29 g/mole, while that of water is 18 g/mole. That becomes important at low altitudes and high temperatures. When low RH increases the density of the external air, the presence of saturated air inside the balloon, becomes an advantage. That is obviously not possible with a vacuum balloon.akhmeteli said:So again, internal saturation does not seem important at low altitudes, and temperature and water vapor content are low at high altitudes.
