MHB How Hot is 10 Degrees Celsius Compared to 5 Degrees Celsius?
  • Thread starter Thread starter Monoxdifly
    Cold Hot
The discussion centers on the question of how to calculate a temperature that is four times hotter than -4 degrees Celsius. Participants highlight that multiplying temperatures in Celsius directly can lead to misleading results due to the scale differences, advocating for conversion to Kelvin for accurate calculations. The consensus is that the question is poorly constructed, as it does not yield a valid answer from the provided options. One participant humorously notes that they were misled by their own question, indicating a lack of clarity in the original premise. Overall, the conversation emphasizes the complexities of temperature scaling and the importance of using absolute temperature scales for such calculations.
Mathematics news on Phys.org
Monoxdifly said:
What is 4 times hotter than -4 degrees Celcius?
A. -16 degrees Celcius
B. -1 degrees Celcius
C. 12 degrees Celcius
D. 16 degrees Celcius
What are your thoughts on the question? :)
In general if something is hotter than another, which direction must it move towards?
Up. But -4 x 4 is -16, and even if I answer 16, a fourth of it is 4, not -4.
I think this question is badly constructed,
If you convert -4 degrees celsius to kelvin units, you'll get ~269.2. Multiplying by 4 then converting back to celsius gives an answer not on the list. However, 4 times a temperature in kelvin is different than 4 times a temperature in a different unit. Each unit has a different scale, so the 4x calculation could drastically differ.
My guess for the intended answer to this bad question would be C, but I'm very curious what the officially response is.
I agree completely. (Nod)
I was also inclined to used an absolute scale such as Kelvins (that avoids negative values), but of course that doesn't lead to any of the choices. :D
There's not any official response since it's a question I myself made up. In other words, I've been tricked by my own question.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
