FusionJim
- 25
- 11
Please help me understand whether my understanding is correct. If I have a solenoid like coil with empty middle , and a magnet that goes through the coil, the coil is longer than the magnet, there is induction as the magnet approaches the coil until the moment when one of the magnet poles is fully immersed into the coil (the field lines have stopped increasing) then as the second pole of the magnet moves inwards the induction goes down to zero. This forms the first half period of a full sine wave, the second half cycle is formed as the magnet exits and the same thing happens as when it entered , so far so good right?
Now what is the reason why there is no induction when the magnet is moving through the part of the coil where both of it's poles are fully encircled by the coil?
1) Is it because equal and opposite field lines cut the same coil at the same time (because both poles of the same magnet are within the coil loop at the same time) ?
2) Or is it because due to both poles being within the coil there is no change in flux since both poles are of equal magnetic field strength ?
I ask this because the way it seems to me is that if the first is true then there is induction in the coil even when both magnet poles are within the coil but it is localized to each magnet pole and the total coil current sums to zero because the currents within the wire adjacent to each pole run in opposite directions, meanwhile if the second is true then there is no current induced (not even a localized one) when the magnet is fully inside the coil because there is no net change in flux.
It would seem to me the localized electrons in the part of coil that faces each magnet pole at each moment should feel the moving field lines from the pole which within the vicinity of each pole are always in one direction , so there should be localized current induced even if the total current is zero due to opposite currents cancelling within the whole coil?
Similarly if I think of the simple experiment where a cylindrical axially polarized magnet is dropped through a conducting pipe, I believe there are localized currents adjacent to each pole as the magnet falls, and each current adjacent to each pole runs opposite to the other current, so in total two counterrotating circular currents.
My last question is this, if in theory (because it doesn't seem to exist in practice) we had a magnetic monopole magnet and this monopole magnet was moving through a very long solenoid shaped coil, if the speed of the moving magnet was constant , would it produce pure DC voltage within the coil?
I would tend to thin - yes, because the field lines from the magnet (all in the same direction) would continually cut the wire inducing a steady current and voltage within the coil. Am I right?
