How integrate 1/(x(1+x^2)^0.5) dx
It would be polite and respectful to put in the minimal effort required to write coherent sentences.In summary, the conversation discusses how to integrate the equation Integrate(1/(x(1+x^2)^0.5) dx. Suggestions are made to substitute x = sin y or x = tan y, and to use the identity 1 + sin^2 y = cos^2 y as a hint for changing variables. The individual asking for help is also reminded to proofread their responses before submitting.
Yuravv
Poster has been reminded to use the Homework Help Template and show their work
Hi everyone, Can you tell me how to integrate the following equation?
Hi Yuravv:
I suggest you try substituting x = sin y.
Hope that helps.
Regards,
Buzz
Buzz Bloom said:
Hi Yuravv:
Hope that helps.
Regards,
Buzz
this dos'n help , do you have any anther suggestion?
tanks a lot.
Substitute ##x=\tan{y}##.
Whenever you see something like ##\sqrt{1+x^2}## that is a reminder that ##1 + \sinh^2y = \cosh^2y##, suggesting that ##x = \sinh y## might be a good change of variables.
Likes Buzz Bloom
tanks a lot.
your answer helped me )
tanks this is help me )
So please show us your work on this integral using the hints you have received...
tanks a lot.
Yes, please proofread what you've written before hitting submit.
FAQ: How integrate 1/(x(1+x^2)^0.5) dx
1. What is the formula for integrating 1/(x(1+x^2)^0.5) dx?
The formula for integrating 1/(x(1+x^2)^0.5) dx is ∫1/(x(1+x^2)^0.5) dx = (1/2)ln|1+√(1+x^2)| + C.
2. What is the technique for integrating 1/(x(1+x^2)^0.5) dx?
The technique for integrating 1/(x(1+x^2)^0.5) dx is substitution. Let u = 1+x^2, then du = 2xdx. Substituting in the original integral gives us ∫(1/2)du/u^0.5 which can be easily integrated.
3. Can the integral 1/(x(1+x^2)^0.5) dx be solved using u-substitution?
Yes, the integral 1/(x(1+x^2)^0.5) dx can be solved using u-substitution by letting u = 1+x^2 and substituting in the original integral to get ∫(1/2)du/u^0.5 which can be easily integrated.
4. Is there another method for integrating 1/(x(1+x^2)^0.5) dx?
Yes, there is another method for integrating 1/(x(1+x^2)^0.5) dx called trigonometric substitution. Let x = tanθ, then dx = sec^2θdθ. Substituting in the original integral and using trigonometric identities, the integral can be solved.
5. What are the limits of integration for integrating 1/(x(1+x^2)^0.5) dx?
The limits of integration for integrating 1/(x(1+x^2)^0.5) dx are determined by the problem or given equation. They can be any finite values or infinity depending on the context of the problem.
9K
