How is a 2-sphere in a 3 dimensional space?
  • Thread starter Thread starter fk378
    Space
fk378
I do not understand how, according to wikipedia, a 2-sphere is a "2-dimensional surface (which is embedded in 3-dimensional space)."
Why is it not a 3-dimensional surface, since we need 3 coordinates to determine a point on the sphere?
no. you only need two coordinates. r is fixed therefore any point is given by the coordinates \theta,\phi. this generalises to hgiher dimensions.
i.e. S^{n} is embedded in n+1 dimensional space.
In class we had an example where U is the set of all vectors x with n+1 coordinates in the n-sphere. How can there be n+1 coordinates in an n-dimensional sphere?
One of the coordinates must be a function of the other n. In the example of the "two sphere", we can identify all points as (\rho, \theta, \phi) using spherical coordinates. But \rho is a constant, the radius of the sphere.
Another example is the plane through (1, 0, 0), (0, 1, 0), and (0, 0, 1). The equation of that plane is, of course, x+ y+ z= 1. Any point on that plane can be labeled (x, y, z) but we can write anyone of those coordinates in terms of the other two. For example, (x, y, 1-x-y). Another possiblilty would be (x, 1- x- z, z). Three coordinates, but written in terms of two parameters- a two dimensional surface imbedded in a three dimensional space.
So if you write it out as (x,y,z) is it still considered to be a 2-dimensional surface? The point is that you *can* write it out in terms of 2 parameters, is this correct?
Yes this is correct, as stated in HallsofIvy's last sentence.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
