MHB How is Group Theory Applied in Music?
Group theory is applied in music through the mathematical relationships that define pitch and rhythm. Music notation utilizes a staff system where notes represent specific pitches and durations, correlating to fractions of measures. The structure of scales and chords can be analyzed using group theory, highlighting symmetries and transformations in musical compositions. Understanding these mathematical concepts can enhance the analysis and creation of music. This application of mathematics in music provides a foundation for projects exploring the intersection of these fields.
Pratibha
Is there any application of maths in music, which topic is directly used. I've heard group theory is used, but how it is used. Plz help..i m going to work on a project that will show how maths works in music or sound system.
Mathematics news on Phys.org
If you know a bit about how to read music, the mathematics of music becomes obvious.
Music is written on a "staff" (five horizontal lines). If you create a simple tempo (amount of time), you can mark this with equally spaced vertical lines, called "measures" or "bars".
A note has two important features, its PITCH (how high or low it is) and its DURATION. So when you see notes drawn on the staff inside each bar, it's telling you WHAT FRACTION OF THE BAR (i.e. how many beats) that each note goes for.
Pitch is also determined by mathematical relationships. I suggest you read this article.
Link
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
