How Is Lift Calculated Using the Bernoulli Principle for an Airplane Wing?
Lift on an airplane wing can be calculated using the Bernoulli Principle by applying the equation P1 + (1/2)densityV1^2 = P2 + (1/2)densityV2^2. Given the air density of 1.29 kg/m^3 and speeds of 347 m/s over the top and 289 m/s under the wing, the pressure difference results in a value of 5.39 x 10^4 N/m^2. This pressure difference is then multiplied by the wing area of 84.5 m^2 to yield a lift force of approximately 4.6 x 10^6 N. The calculations confirm the application of Bernoulli's equation for determining lift. The method used for this calculation is deemed correct.
th3plan
Find the lift in Newtons due to the Bernoulli Principle on a wing of a plane of area 84.5 m^2 if the air passes over the top and the bottom surfaces at speeds of 347m/s and 289 m/s
P1+(1/2)densityV^2 =P2+(1/2)densityV^2
Ok so i know the density of air is 1.29kg/m^3
so i plug into equation to get
1/2(1.29kg/m^3)(347m/s)^2= 1/2(1.29kg/m^3)(289m/s)^2
then i get answer of 5.39x10^4 N/m^2
then i use equation F=PA
and P is 5.39x10^4 N/m^2 and A is 84.5m^2
to get answer of 4.6x10^6 N
Am i correct ?
By bernouili equation
Pa+1/2pva^2 = Pb =1/2pvb^2
1/2pvb^2-1/2pva^2 =Pa-Pb
deltaP = 1/2pvb^2-1/2pva^2
deltaP * A =Lift force
I think your method is correct
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
