How Is the Effective Conductivity of Sediment Layers Calculated?
  • Thread starter Thread starter KEØM
    Conductivity Set
The discussion focuses on calculating the effective conductivity of sediment layers using Ohm's Law and the concept of resistors in parallel. The user attempts to derive the effective conductivity formula for a system of N layers, expressing it in terms of layer thickness and conductivity. They explore the relationship between resistivity and conductivity, questioning the geometrical factors involved in their calculations. The user seeks verification of their approach and clarification on the geometrical factor for the z-direction. The conversation emphasizes the complexities of applying these principles in a geophysics context.
KEØM
We consider the following configuration. A pile of N layers of sediments. Each layer has a conductivity \sigma_{i} (i from 1 to N) and a thickness m_{i}. The length of the system is L. In this case, the electrical conductivity is not a scalar but a second order symmetric tensor.
Using Ohm's Law and the idea of resistors working in parallel, demonstrate that the effective conductivity of the block along the x-direction is:
\sigma_{x} = \frac{\Sigma_{i=1}^{N} m_{i}\sigma_{i}}{\Sigma_{i=1}^{N} m_{i}}<br />
\vec{j} = -\underline{\sigma} \vec{\nabla} V, <br /> <br /> \underline{\sigma} = \begin{bmatrix}<br /> \sigma_{x} &amp; 0 \\<br /> 0 &amp; \sigma_{z} <br /> \end{bmatrix}} <br /> <br />
I am not exactly sure if this qualifies as advanced physics. This is a geophysics course and I have never seen this before (not even in the course).
The first thing I did was I used the product over sum formula for two parallel resistors.
R_{eq} = \frac{R_{1} R_{2}}{R_{1} + R_{2}}
Now using the formula R = \frac{\rho}{g}
where \rho is the resistivity of the specific layer and g is the geometrical factor (I don't know what this is in this case and I don't know how to use it).
Substituting this in for R and using \rho = \frac{1}{\sigma} this parallel equation, after a lot of algebra, becomes:
R_{eq} = \frac{1}{g_{1} \sigma_{1} + g_{2}\sigma_{2}}
Now, can I set R_{eq} = \frac{1}{\sigma_{x} g_{eq}} , g_{eq} = g_{1} + g_{2}?
And then can I go as far as setting g equal to m?
If that is the case then I will have the correct answer because,
\frac{1}{\sigma_{x}(m_{1} + m_{2})} = \frac{1}{m_{1} \sigma_{1} + m_{2}\sigma_{2}}<br /> <br /> \Rightarrow \sigma_{x} = \frac{m_{1} \sigma_{1} + m_{2}\sigma_{2}}{m_{1} + m_{2}}.<br /> <br />
Which is the formula for the specific case of N =2.
Could someone please verify my approach or let me know how horribly wrong I am?
Thanks in advance,
KEØM
I did some thinking and I think I got it. If I manipulate \vec{j} = -\underline{\sigma} \vec{\nabla}V into V = IR by letting \nabla V_{x} = \frac{\Delta V}{\Delta x} and
\nabla V_{z} = \frac{\Delta V}{\Delta z}
then the magnitude of my first equation will become
j = \sigma_{x}\frac{\Delta V}{\Delta x} in the x-direction
and
j = \sigma_{z}\frac{\Delta V}{\Delta z} in the z-direction.
Then in the x-direction:\frac{I}{A}= \sigma_{x}\frac{\Delta V}{\Delta x} <br /> <br /> \Rightarrow \Delta V = \left( \frac{\Delta x}{A \sigma_{x}} \right)I.<br /> <br />
But as is apparent in the diagram (I will post this in a bit)\Delta x = L and A = \Delta x m = Lm
The above equation then becomes:
\Delta V = \left( \frac{\rho_{x}L}{mL} \right)I
The L's cancel and this gives me V = IR where
R = \frac{\rho_{x}}{m}}.
Hence m is my geometrical factor.
I do this same process for the z-direction (with \Delta z = m) and I get my R to be:
R = \frac{\rho_{z}}{L}}.
So then L must be my geometrical factor for the z-direction? A problem further into my worksheet asks for me to give the expression for \sigma_{z} similar to that of \sigma_{x} in the first problem. But using L as my geometrical factor I do not get the correct result.
Can someone please verify my answers here and help me with the geometrical factor in the z-direction?
Thanks in advance,
KEØM
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
