How Is the Initial Current Calculated in a Discharge Graph?
The discussion revolves around calculating the initial current in a discharge graph for a capacitor discharging through a resistor. The initial voltage used in the calculations is questioned, as the provided answer states 1.6 V instead of the expected 12 V from the charged capacitor. The energy stored in the capacitor is calculated to be approximately 0.16 J, with the efficiency of the motor determined to be 75%. The time constant for the discharge is confirmed to be around 35 ms, leading to confusion about the current values at t=0 and t=35 ms. Ultimately, the discrepancy in voltage values highlights a misunderstanding in the problem's context.
Masafi
Hi, I need help with the last part. I have put each part with the answers.
For b) ii) I want to know where does V=1.6 V come from?
(a) A 2200 µF capacitor is charged to a potential difference of 12 V and then discharged through an electric motor. The motor lifts a 50 g mass through a height of 24 cm.
(i) Show that the energy stored in the capacitor is approximately 0.16
E = ½ CV^2 = 0.5 × 2200 × 10(–6) F × (12 V)^2
E = 0.158 J
(ii) What is the efficiency of the electric motor in this situation?
E = mgh = 0.12 J
Efficiency = 0.12 ÷ 0.16 J = 0.75
(b) The capacitor is charged to 12 V again and then discharged through a 16  resistor.
(i) Show that the time constant for this discharge is approximately 35 ms.
t = RC = 35.2 s
---- I need help with ----
(ii) Sketch a graph of current against time for this discharge on the grid below. You should indicate the current at t = 0 and t = 35 ms.
Curve starting on I axis but not reaching t axis
I = 1.6 V / 16Ohms = 100 mA shown on axis
Curve passing through about 37 mA at t = 35 ms
What is the equation for current as a function of time? Hint: it is the solution to the differential equation:
V_C + V_R = 0 where V_R = IR = R(dQ/dt) and V_C = Q/C
So:
\dot Q + Q/RC = 0[/itex]<br /> <br /> AM
So:
<br /> <br /> Is there any other way, because this is precalculus physics?
The solution is:
Q = Q_0e^{-\frac{t}{RC}}
so:
\dot Q = I = \frac{V}{R} = -\frac{Q_0}{RC}e^{-\frac{t}{RC}} = -\frac{V_0}{R}e^{-\frac{t}{RC}}
Can you graph that?
AM
Andrew Mason said:
The solution is:
so:
Can you graph that?
AM
Yeah, so at t=0, I = 12V/16ohms = 0.75A
But the answer uses 1.6V, which I am not sure where they get from...
"I = 1.6 V / 16 = 100 mA shown on axis "
Shouldn't it be 12V since it says:
"The capacitor is charged to 12 V again and then discharged through a 16ohms resistor"
The time constant is approximately 35s, as the capacitance is 2200 microF.
On the graph in the answer, they have Current = 37mA at t=35, and Current = 100mA at t=0?
Basically, I can't get how they get the orignal V to be 1.6V, rather than 12V - there was no mention of 1.6V in the question...
You are right. The answers given correspond to an initial voltage of 1.6 V, not 12. The correct answers are 750 mA and 277 mA.
AM
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
