How Is the Value of 'm' Determined in Interference Equations?
  • Thread starter Thread starter hyde2042
    Waves
The value of 'm' in interference equations is determined as any integer, including zero, which is often used to simplify calculations. Using 'm=0' is preferred for thinner coatings because it results in lower reflectance at specific wavelengths, maintaining low reflectance across a broader range. The reflectance spectrum indicates that thinner coatings, such as 100 nm, can achieve zero reflectance at a given wavelength, like 600 nm, more effectively than thicker coatings. This approach helps in optimizing the design of optical coatings. Understanding these principles is crucial for accurately determining the thickness of materials in interference applications.
hyde2042
http://i.imgur.com/xrba7.png
I'm using this equation to find the thickness of the polymer.
[(m+(1/2)) λ = 2nt] (where "n" is the index of refraction and "t" is the thickness )
I just want to know how m is determined. I've learned everything else, but I missed the first day on which m value to use and it's always just slipped my mind whenever I'm in class or lab.
Thank you for your time.
m is any integer, including zero. ehild
Thanks, but I'm still unsure as to why "0" is used in the solution instead of "1" or "2".
First: it is easier to make a thinner coating then a thick one.
Second: The reflectance depends on the wavelength, this function is about the form R=A+Bcos(4piND/lambda) (N is the refractive index, D the thickness). If the reflectance is zero at a specific wavelength, it stays low in the broadest wavelength range when D has the smallest possible value.
The figure shows the reflectance spectrum of two coatings, one 100 nm, the other 300 nm thick. Both have zero reflectance at 600 nm.
ehild
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
