How is this supposed to be read?
  • Thread starter Thread starter brotivation
brotivation
km/hr•s
This is a car accelerating. Also, how would I convert it into km/s^2?
It should be read as km per hour per second.
Thank you that's all I needed.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
