How is Wave Intensity Affected by Half Amplitude and Double Frequency?
In summary, the conversation discusses finding the intensity of a wave and the relationship between intensity, amplitude, and frequency. The questioner is unsure of the equation that relates intensity to amplitude and frequency and is asking for clarification. They also mention that the question is part of a proof and that they have seen the answer already. The conversation also addresses the importance of writing clearly and understanding context when discussing physics concepts.
homeworkhelpls
41
TL;DR Summary: How do i find the intensity of this wave?
I know I is proportional to amplitude / frequency squared, but I don't know what equation this comes from. And I don't know how to answer this.
Let's start with the basics: do you know the difference between amplitude and frequency?
Yes, brother im an undergrad
What kind of wave is this? And what is x on the vertical axis? Is it linear displacement of the particles in the wave?
doesnt matter, the question is used to ultimately prove that intensity of both waves is the same, its a proof question
Ok. So is intensity proportional to the square of the amplitude or of the frequency, or what?
@homeworkhelpls, you might be puzzled by these responses:
But I'd say the cause is some ambiguity in your post:
I can read that as:
  • ##(\frac{amplitude}{frequency})^2##
  • either ##{amplitude}^2## or ##{frequency}^2##, but not sure which or whether it matters
  • both ##{amplitude}^2## and ##{frequency}^2##
My guess is that you meant the third, whereas @Ibix read it as the second.
Likes Ibix
There's a point here about writing clearly, @homeworkhelpls . You saved yourself two characters by writing / writing of "and". You'd probably have had your answer this morning if you'd spent the two extra characters.
It does matter to know what quantities are represented on the axes. You may know it but out of context is not obvious.
No i don't know it, you're not supposed to know it bro i saw the answer
  • Skeptical
Likes Motore
haruspex said:
@homeworkhelpls, you might be puzzled by these responses:But I'd say the cause is some ambiguity in your post:
I can read that as:
Damn guys my bad lol, no all three guesses were wrong i meant the physics law of intensity where, I is directally proportional to amplitude squared
kuruman said:
Maybe you will find this link useful.
lol, what if i have no heat source
  • Sad
Likes Motore
See if this helps https://physics.info/intensity/
It is not clear what your difficulty is. You don’t need the equation to apply proportionality. For example: the area of a circle is 100cm²; the radius is halved; what is the new area? (No equations needed.)
From the graphs:
1: what is the value of ##\frac {A_P}{A_Q}## (where ##A## is amplitude)?
2: what is the value of ##\frac {f_P}{f_Q}## (where ##f## is frequency)?
In terms of proportionality:
3: how is intensity related to amplitude if all other parameters are kept constant?
4: how is intensity related to frequency, if all other parameters are kept constant?
If you can answer all 4 questions, you should be able to solve the problem.
You know that this is related to some chapter in a book where a specific type of wave is described. Possibly just a plane wave in 1 dimension. But this is not the only wave possible and a linear dispalcement (position of particle) is not the only parameter used to describe a wave. What you know in the context of the specific book is not obvious for the people outside that context. A sound wave is most commonly described by the acoustic pressure and not particle displacement, for example.
Bruh relax I’ll just send answer
  • Sad
Likes Motore
