How Long Will It Take to Heat Water in an Electric Kettle?
  • Thread starter Thread starter chawki
The discussion centers on calculating the time required to heat 0.85 kg of water by 20 °C in an electric kettle using a 25 Ohm resistance connected to 230 V. The specific heat capacity of water is noted as 4190 J/(kg°C), leading to a total energy requirement of 71230 J. Power is calculated using the formula P=V²/R, resulting in 2116 watts. The time to heat the water is then derived using the formula t=Q/P, yielding approximately 33.66 seconds. The solution is confirmed as correct, with a suggestion to annotate the calculations for clarity.
chawki
In an electric kettle with good heat insulation 0.85 kg water is warmed by an electrical resistance of 25 Ohms, which is connected to a voltage of 230 V. The specific heat capacity of water is 4190 J/(kg°C)
In what time will the temperature of the water rise by 20 °C?
P=E/t
but here we can calculate only Q
are they the same?
Compare the units. One is a rate, the other is an amount.
Power is Joules/second. Heat is Joules. One is a rate, the other an amount.
Yes, i was meaning Q and E
i was meaning if we can write P=Q/t anstead of P=E/t...because both Q and E are energies and joules.
This is how i solved it..
Q=m*Cp*delta T
Q=0.85*4190*20
Q=71230 J
then we calculate P
P=V2/R
P=2302/25
P=2116 watt
P=Q/t
t=Q/P
t=71230/2116
t=33.66 seconds ?
Forms of energy are interconvertible under the appropriate circumstances. Certainly electrically produced heat energy can be used to add heat to physical substances.
Is my answer and the way i have written it correct ?
Sure. Well done. Although if you have time, you should annotate the calculations a bit to explain what it is you're calculating in each section. It's a bit like writing good computer code... imagine that someone who has never seen it before needs to understand it in a hurry.
Thank you gneill o:)
