How Magnetic Flux Causes Load on Generators
In summary: When you apply a load to a generator, does the generator's spinning speed increase as well, or does the load apply a force to the generator that opposes the spinning speed?
Elmo Lopez
this might have been answer before. Question is, what in physics or chemistry creates a load on a generator when the demand increases. For example, If no lights are turned on connected to a generator, it will spin freely. but the more lights are turned on the harder is to spin the generator.
What causes this increase in torque requirement. for example the windings in the generator can be mounted in the stator. it doesn't even touch the rotor. so why the increase in torque required to spin the generator as the load demand increases. what causes it?
is it an increase in magnetic flux caused by the windings of the generator that oppose the magnetic field of the rotor?
for someone that doesn't understand physics, it would be rational that the spinning torque required shouldn't change regardless of the electrical demand on the generator.
thank you,
Read a bit of this: https://en.wikipedia.org/wiki/Eddy_current
The "demand" on the generator has to do with the electrical resistance in the circuit. Limiting the current flowing and thus the "drag" created by eddy currents.
This is my lamens explanation as I understand it.
A generator and a motor are the same device. Why does the motor output increase when you increase the input power (torque, rpm, whatever)?
The simple answer is that motors and generators push and pull electrons through wires, which is both a physical and electrical force.
Likes Dale
One answer it that it has to be so in order to satisfy conservation of energy. You can't get more electrical energy out of a generator than the mechanical energy you put in. So if you draw more power out by increasing the load it's only reasonable you will have to supply more input power.
Yes!
Remember that in order to have a magnetic force you have to have a wire moving through a magnetic field, breaking the magnetic field lines (or the opposite, thus magnetic field lines moving and breaking through the wire). When there's no resistance in the circuit then the generator pushes the electrons and they just start flowing at whatever speed the generator is asking them to flow, the motion of the magnetic field lines and the wires in the generator get synced up, there's no forces developed and the generator just kind of spins with the current or the current flows with the spin of the generator...whichever way you prefer to look at it.
Apply a load and it will push back on the current, slowing it down. Now there's a mismatch in the motion of the magnetic field lines and the generator wires, the magnetic field lines get broken by the generator, and you get a force that tends to slow the generator down.
I'm kind of a layman and it's been a while since I looked at electric circuits, so someone please correct me if I'm wrong.
Related to How Magnetic Flux Causes Load on Generators
1. What is magnetic flux?
Magnetic flux is a measure of the amount of magnetic field passing through a given area. It is represented by the symbol Φ and is measured in units of webers (Wb).
2. How does magnetic flux cause load on generators?
Magnetic flux is a crucial component in the generation of electricity in generators. As the rotor of a generator spins, it creates a changing magnetic field. This changing magnetic field induces a current in the stator windings, which in turn generates electricity. Therefore, the amount of magnetic flux passing through the stator windings directly affects the amount of electricity produced.
3. What factors affect the amount of magnetic flux in a generator?
The amount of magnetic flux in a generator is affected by several factors, including the strength of the permanent magnets in the rotor, the speed of rotation, and the number of turns in the stator windings.
4. How does the load on a generator change with magnetic flux?
The load on a generator is directly proportional to the amount of magnetic flux passing through the stator windings. As the magnetic flux increases, the induced current and thus the electricity produced also increases. This relationship is known as Faraday's Law of Induction.
5. Can magnetic flux cause damage to generators?
Excessive magnetic flux can cause overheating and damage to the stator windings in a generator. This can occur if the generator is overloaded or if the permanent magnets in the rotor are too strong. Proper maintenance and monitoring of magnetic flux levels can help prevent damage to generators.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
