MHB How many balls can fit into a jar
  • Thread starter Thread starter hatelove
    Balls Fit
The volume of the jar is approximately 2,714.34 cubic inches, while the volume of each ball is about 4.19 cubic inches. Dividing the jar's volume by the ball's volume suggests that 648 balls can fit inside. However, this calculation does not account for the spaces between the balls, which can significantly reduce the actual number that can be packed. The maximum packing efficiency for spheres is around 74%, indicating that the practical number of balls fitting into the jar would be lower than 648.
hatelove
The jar has a radius of 6" and a height of 24" and each ball has a radius of 1".
So I found the volume of the jar which is \pi6^{2}(24) = \approx 2,714.33605 and the volume of the balls which is \frac{4}{3}\pi1^{3} = \approx 4.1887902
And then I divided how many of the balls can go into the jar by dividing:
2714.33605 \div 4.1887902 = 648 balls
Does that number take into account the spaces between the balls when put into the jar? Like the small gaps when spheres are placed next to each other.
Mathematics news on Phys.org
No, the maximum packing fraction that can be achieved with regular packing and no boundary effects is ~74%, and the random close packing packing fraction is ~63%.
See: >>here<< and >>here<<
CB
Hello, daigo!
How many balls can fit into the jar?
So I found the volume of the jar which is: \pi6^{2}(24) = \approx 2,714.33605
and the volume of the balls which is: \frac{4}{3}\pi1^{3} = \approx 4.1887902
. . ]2714.33605 \div 4.1887902 = 648\:balls
Does that number take into account the spaces between the balls when put into the jar? . . . . no
First of all, I'd do your math like this:
Volume of jar: \pi(6^2)(24) \:=\:864\pi
Volume of ball: \tfrac{4}{3}\pi(1^3)\:=\:\tfrac{4}{3}\pi
Therefore: .864\pi \div \tfrac{4}{3}\pi \:=\:648\text{ balls}
You see, I hate long (and incomplete) decimals.
. . I hate writing them down, I hate entering them on my calculator.
I would do anything (even Algebra) to avoid that.Second,you have melted the 648 balls into a puddle.
. . Then you poured the liquid into the jar.
If the ratio of the dimensions of the jar compared to the dimensions of the diameter of the ball were large (it is not in this case), then the answer to the question of how many balls of 1 " radius could you put inside a jar of radius 6 " and a height of 24 " would be 648 times a "density constant" of about 0.5, or, 648 * 0.5 = 324. Let's call it 330 plus/minus 10. The larger the jar (and/or the smaller the marble), the higher the "density constant" would be. If you were figuring how many 5/8" diameter marbles (2 cc each) would go into a 1 gallon jar (3785 cc's), for example, the calculations would be:
3785/2*0.6 = 1324.75
or about 1330 plus/minus 10 marbles. The "density constant" here is 0.6. If you have a VERY LARGE container with VERY SMALL marbles, the density constant would be a maximum of 0.74.
https://www.physicsforums.com/threads/advanced-or-simple-balls-in-a-jar-probability.817893/
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 22 ·
